Forum: DAZ|Studio
Subject: bad hair day
dustfae opened this issue on Jan 14, 2007 · 3 posts
dustfae posted Sun, 14 January 2007 at 3:58 AM
I am new at this so I hope someone can help me. When I apply some but not all hair objects they look like this! Could anybody please tell me how to fix this?
RHaseltine posted Sun, 14 January 2007 at 2:00 PM
That's a consequence of the different ways Poser and D|S handle transparency  -the maker has left a transparency map on the surfaces that should be opaque, because in Poser it doesn't have any effect - in D|S it does (in most cases, as here, it makes the surface wholly transparent).
Go to the Surfaces palette (View>Tabs>Surfaces)  and use the drop-down list at the top to find the hair, then look for a surface name under that sounds as if it should be the body of the hair. Select it and in the Opacity section of the palette click the button with the file name and select None instead of the file name. If that doesn't bring at least some of the hair up (leaving the areas you can currently see as loose strands over the top) undo and try another material name. Once you are donw, save as a material preset so that you can easily reapply the fix in future.
dustfae posted Mon, 15 January 2007 at 6:26 AM
Thank you so much!! I was ready to pull out my own hair!!! :lol:
