psyvampiress opened this issue on Jan 16, 2007 · 5 posts
psyvampiress posted Tue, 16 January 2007 at 12:15 PM
Hi all,
How do I make subdirectorys for my runtime folder? When I make my dynamic clothes, they go straight under props. How do I make it like props/miki/leatherout ??
Thanks! :)
dbowers22 posted Tue, 16 January 2007 at 12:23 PM
Just go to Windows Explorer (if you are using Windows) and create a subdirectory.
Then move your files into it.
Jules53757 posted Tue, 16 January 2007 at 12:49 PM
On the library tab clock on the little triangle on the top right and select add new category. Thats it.
Ulli
thefixer posted Tue, 16 January 2007 at 1:23 PM
The library folders hierarchy are the same as any other folder system. Be sure NOT to touch your main library folders, but inside of them you can add as many sub folders and sub folders of sub folders as you want!
Navigation of sub folders is easy if you use the little black triangle on the right hand side!
Injustice will be avenged.
Cofiwch Dryweryn.
ashley9803 posted Wed, 17 January 2007 at 9:14 AM
***"Just go to Windows Explorer (if you are using Windows) and create a subdirectory.
Then move your files into it."
Specifically you want to - right click - new - folder then name it.
Same thing I know.
