Subject: Windows xp or Windows X64
SoulTaker opened this issue on Jan 18, 2007 · 9 posts
SoulTaker posted Thu, 18 January 2007 at 5:04 PM
i am thinking of upgrading and was thing of getting win 64, what i would like to ask is is it worth it?
your comments would be welcome
AnAardvark posted Thu, 18 January 2007 at 6:25 PM
Does your computer have a 64-bit architecture? If not, it won't benefit from Win 64 (and it might not even run.) If it does have it, then it will benefit, but not, IIRC, for Poser 7 or less. (Eventually there will be a 64-bit version of Poser.)
Acadia posted Thu, 18 January 2007 at 6:25 PM
Well, in my "help me build a new computer" thread, the recommendation given to me by everyone said Windows XP Pro 64 Bit.  So that's what I am getting with my new computer.  I was told to stay away from Windows Vista for the time being because of the problems with it.
pjz99 posted Thu, 18 January 2007 at 6:26 PM
IF you have good drivers for all your peripherals, and if you have more than 2GB of physical memory (RAM), then yes, imo it's very worth it.  I currently run Windows XP 64 (not Vista) and I'm very happy with it so far.  The 32-bit software I have runs very well, and 64-bit apps (Vue 6 Infinite e.g.) work much better.  64-bit software has no practical limit for RAM it can allocate, which is pretty cool; 32-bit software is still limited to 3GB, which you could get to under XP 32 with some tweaking.
My Freebies
AnAardvark posted Fri, 19 January 2007 at 12:09 AM
Quote - Well, in my "help me build a new computer" thread, the recommendation given to me by everyone said Windows XP Pro 64 Bit.  So that's what I am getting with my new computer.  I was told to stay away from Windows Vista for the time being because of the problems with it.
Ah, I thought you were talking about upgrading the OS on an existing machine.
AnAardvark posted Fri, 19 January 2007 at 12:13 AM
Tell me about it. I suspect that a lot of software produced by small companies just won't run under Vista because it expects to be in admin mode -- I've seen this happen in my day job, but the migration has to be done.
If you buy a machine from HP between now and the Vista Home Edition role-out, you will be able to upgrade to Vista for free, BTW.
thefixer posted Fri, 19 January 2007 at 2:17 AM
There are a lot of threads going on about Vista, all of them negative, something to do with OTT security problems with programmes not running on it, even the industry is getting wet knickers about it!!
Injustice will be avenged.
Cofiwch Dryweryn.
ugpsobta posted Fri, 19 January 2007 at 6:35 AM
i run xp64 on my rendering machine as part of a dual-boot configuration.  it works great,  a bit of a challenge but well worth it.  also, a word to the wise, spend a few bucks and install it on a large separate hard drive.  i also installed 4 gigs of dual channel memory and poser seven runs like a dream..  follow the links from 'planet 64' for instructions on a multi boot installation.  carrara plays very well in this environment as well.
hoppersan2000 posted Fri, 19 January 2007 at 1:54 PM
I am in total agreement with ugpsobta, make your machine a dual boot.  Poser 7 with Windows XP 64bit is a finicky beast at best.  You will get to enjoy the old popular BSOD on occassions.  I usually pose on the 32 bit side and move to 64bit for rendering.  This allows me to take advantage of my extra memory.  Just understand that you will get somewhat of a speed increase due to any memory you have beyond 3.5 gigs, you will not see a performance enhancement due to the 64 bit OS.
