Subject: Un-parenting props
ashley9803 opened this issue on Jan 22, 2007 · 8 posts
ashley9803 posted Mon, 22 January 2007 at 3:12 AM
I have occasionally parented props to body parts and later decided I no longer wanted the prop to be parented to anything. The only thing I could do was delete it and add a new one.
There is no "parent to none" option, like there is a "conform to none option".
Just how do you un-parent a prop in a P6 scene?
kuroyume0161 posted Mon, 22 January 2007 at 3:14 AM
Parent to UNIVERSE.
 -- Bjarne Stroustrup
pjz99 posted Mon, 22 January 2007 at 3:32 AM
^^ yep.  It is a little counter intuitive.
My Freebies
ashley9803 posted Mon, 22 January 2007 at 6:23 AM
Thought I tried this and it didn't unparent.
Well, off to try again.
Thanks guys.
diolma posted Mon, 22 January 2007 at 3:35 PM
Parent to Universe is correct - usually...
But if the prop is parented with "Inherit bends of Parent" checked (and you can't know, if it was a 3rd-party prop), then unparenting can cause problems.
If "Parenting to Universe" causes the prop to do something wierd, the alternatives that might work are (IIRC):
Hope that helps,
Cheers,
Diolma
ashley9803 posted Mon, 22 January 2007 at 5:51 PM
Interesting.
Thanks Diolma.
Jim Burton posted Mon, 22 January 2007 at 7:30 PM
I think if you just open the prop with out enything present to parent to, and resave it, it looses all parenting.
But it couldn't be that easy, could it?  ;-)
diolma posted Tue, 23 January 2007 at 1:32 PM
"*I think if you just open the prop with out enything present to parent to, and resave it, it looses all parenting.
But it couldn't be that easy, could it?*   ;-)"
Come to think of it, yes, it probably is that easy. In fact, just re-saving back to the props library (when parented) should work, just say "NO" when you get the dialogue asking "Save as a Smart Prop"?
Although I would always advise saving as a new prop, rather than overwriting the original...
Cheers,
Diolma
