DreamersWish opened this issue on Jan 24, 2007 · 3 posts
DreamersWish posted Wed, 24 January 2007 at 8:58 PM
I was trying to look at some old FE spotfiles I had made in the past. When I tried to bring them up in FE I kept getting these error reading: "Create comple process failed; System error: The perameter is incorrect." Then I would get "DLL not compiled. Make compilation window visible and check for errors in the formula code."
Is there anyone who might know what is going on. I have a lot of spotfiles from that time that appearently used that same sort of perameter. I would appreciate any help if possible. Thank you for taking the time to look and any help given.
Pannyhb posted Thu, 25 January 2007 at 10:27 PM
Which version of FE are you using? Some of the newer versions are either incompatible with old spot files or need a little tweaking. Also - is your formula compiler unzipped into your main FE folder?
DreamersWish posted Fri, 26 January 2007 at 11:05 AM
The version is 2.02. As far as I can tell the compiler is in my main FE folder. I have made an FE file that has all the unzipped items that it came with (v. 2.02) and added the compiler. Have I put it in the wrong place? Thank you so much Pannyhb for the help. I truly appreciate it.
