Subject: new problem with clothes
ComplexDarkness opened this issue on Jan 30, 2007 · 27 posts
ComplexDarkness posted Tue, 30 January 2007 at 7:39 PM
ok ive finally figured out the whole drop too floor thing ok well i hope u can see this picture.. as soon as i put her in a pose her body pokes through them :/ wat am i doing wrong here? am i supposed too put the pose first and then clothes? Photobucket - Video and Image Hosting
PhilC posted Tue, 30 January 2007 at 7:49 PM
Did you apply the V4 magnets to the clothing?
ComplexDarkness posted Wed, 31 January 2007 at 7:20 AM
ummmm no ?? :/ how do i do that? and this is a V3 not V4
4blueyes posted Wed, 31 January 2007 at 7:59 AM
Looks like the nipple morphs (if dialed on Vicky) are not supported in the clothing item (or you have to find and dial them manually). There can be a problem with the Collars JCMs too (from what I see in the upper chest pokethrough) - mostly you need to dial them manually too in Poser. Some clothes have the dials on the Body part and some have them in the chest and both collars - look for something like "l/rCollarBend" or "l/rCollarUp". Hope this helps somehow :) Michal 4blueyes
Letterworks posted Wed, 31 January 2007 at 8:02 AM
First, make sure that the clothing is for the figure and any CHARACTER MORPH you may be using.
Second, check the Body and/or the collar groups to see if there are corrrection morphs for shoulders up, shldr up etc.
Third, if you have used a morph to give V3 larger nipples the clothing doesn;t appear to made to accomodate them.
V3 has Joint Controled morphs that raise the breasts when the shoulders are raised and vice versa. Some clothing have morphs that make this adjustment automatically, others have to have the correction made manually with a morph dial.
Remember, unlike real clothing (or clothing used in the cltoh room) poser conforming clothing is more like plastic than cloth, so it's not really universal.
mike
ComplexDarkness posted Wed, 31 January 2007 at 1:31 PM
ok im stuck..you lot confused me :P....now ive done a new pose shes lying down sideways leaning her head on her arm...ive added a skirt and a top but again the body is poking through it..can someone give me a step by step helpage lol as too how too correct this ? :/ pleaseeeeee lol
Tiari posted Wed, 31 January 2007 at 3:35 PM
LOL helpage.
In your folders that came with v4 you'll find magnets.  I think its props, could be wrong.  Click on the magnet for chest, and then select it in the workspace.  You should be able to pull the magnet out a fraction and the shirt will move out along with it.
In any other instance, if you dont want to do that, select the chest part of the shirt, and go to your dials on the right, and use the scale dials, just a little bit.  Since your chest area isnt completely hanging out of the shirt, a bit of scaling (probably z scale) should just cover them nice nice.
ComplexDarkness posted Wed, 31 January 2007 at 3:43 PM
well i dont see any magnets :/ ...but ill try the second part..
ComplexDarkness posted Wed, 31 January 2007 at 3:55 PM
ok the scaling bit doesnt work..it just makes the shirt bigger at the back if u know what i mean :/..do you know where the magnets are..runs around screaming lol!!!
ComplexDarkness posted Wed, 31 January 2007 at 4:06 PM
i mean check this one out Photobucket - Video and Image Hosting i mean what the hell lol and these are clothes from freebies for V3
Letterworks posted Wed, 31 January 2007 at 4:56 PM
OK, let's take this back a ste or three!
First: Is this V3 or V4? I assumed it was V3 but others are assuming it's V4.
Note: If you are using clothing made for V3 on V4, there is no simple way to make the clothing work with the figure.
Second: Just what is the name of the clothing items? I'd like to check over the items to see what morphs are available in them.
Note: V3 requires morphs to match the figure's internal Joint Controled Morphs, which create more realistic "movement" in the figure. V4 on the other hand uses a, realitively, new system of magnet poses for match the clothing to the magnets which have replaced JCMs.
Still the main thing is that the clothing must be made for the figure.
mike
ComplexDarkness posted Wed, 31 January 2007 at 5:29 PM
well heres one top or thee top i had the 1st prob with .. http://www.renderosity.com/mod/freestuff/index.php?section_id=201&&page=4 the wifebeater http://www.renderosity.com/mod/freestuff/index.php?section_id=201&&page=7 mini skirt in pic 2 and riggght at the bottom of this page is the green top :)
PhilC posted Wed, 31 January 2007 at 5:35 PM
If it is V3 try bending the figures buttocks rather than the thighs. If the skirt only contains a hip group bending the figure's thighs will have no effect on it.
kuroyume0161 posted Wed, 31 January 2007 at 5:43 PM
You still haven't answered any of the questions.  I see how you came up with your pseudonym, ComplexDarkness.  You're making this complex and keeping us all in the dark... ;P
Which figure are you using?  Victoria 3?  Victoria 4?  That makes the entire difference.
V4 uses magnets to form clothing to work with V4 morphs.
V3 doesn not.  For V3, the morphs must also be on the clothing that match those being used on the V3 figure or you have to do some work to circumvent poke-through and morph-through.  Usually this work involves - er - Poser magnets.  Look 'em up - they're in the manual. :)
 -- Bjarne Stroustrup
modus0 posted Wed, 31 January 2007 at 5:53 PM
Quote - ummmm no ?? :/ how do i do that? and this is a V3 not V4
I think that's the answer to everyone's question.
Letterworks posted Wed, 31 January 2007 at 5:56 PM
ah, thanks modusO I missed that answer up there. I'll have a look at the cloths and be back soon.
mike
kuroyume0161 posted Wed, 31 January 2007 at 5:57 PM
Thanks, modus. I suspected as much - missed that in the larger picture.  Well, now it's time for someone to describe how Poser magnets work.  Most likely, being freebie V3 clothing, they don't come with a large stock of V3 complimentary [sic] morphs.  It's rare to find a good coverage in commercial clothing.
kayjay97 posted Wed, 31 January 2007 at 6:22 PM
there are morphs in the body of the skirt including sitting morphs. There are also morphs in the hip of the skirt
The downlaod page, when you click on the pic of the skirt, has these instructions and morph listing
You'll find this item under the folder of Poser - Figures > Meanderings EveryDay.
After conforming, if you select the BODY of this item, you have access to 15 dials:
NOTE: This item use JCM automatic morph system, you need to have your V3 character loaded and selected before loading and conforming this item.
There are no morphs in the shirt
In a world filled with causes for worry and anxiety...
we need the peace of God standing guard over our hearts and minds.
Jerry McCant
ComplexDarkness posted Wed, 31 January 2007 at 7:05 PM
thank u so much//and no morphs in the shirt? does that mean it wouldnt be able too fit?
Letterworks posted Wed, 31 January 2007 at 7:08 PM
Well I've just finished trying both the skirt and the wifebeater shirt.
  1. The skirt has all of the morphs necessary fo fit any poser V3 can make within reason, HOWEVER there are supposed to be Joint Controlled Morphs for bending the legs, twisting, etc. These are in the HIP group and use names like "JCM_TR_BendF". These JCMs don;t appear to work automatically (at least I couldn;t get them to work with out manually operating the dials!) but need to be dialed in by hand. Not sure where the problem is in the CR2 that causes them not to work but there it is. Dialed by hand the work just fine,
  2. the shirt has NO morphs in it so certain "extreme" pose just won't work without poke thru. In particular poses the move the Collar groups up or down to any great extent are going to cause th type of poke thru your experienceing. THis is stated in the readme files.
Hey these are Freebies after all. They are nicely modeled and very useful models you just have to learn their limits and use them in that range. Both poses you are showing have the collar groups bent to an extreme. Try something a little less aggressive and the shirts will work fine, either that or find a shirt with the collar morphs included.
mike
kayjay97 posted Wed, 31 January 2007 at 7:09 PM
Quote - thank u so much//and no morphs in the shirt? does that mean it wouldnt be able too fit?
It will only fit the default V3 body unless you use magnets or something on the shirt
Jerry McCant
ComplexDarkness posted Wed, 31 January 2007 at 7:40 PM
thanks alot :) i managed too mend the skirt apart from the gap on her thigh..what dial did u use to correct it ?:/
ComplexDarkness posted Wed, 31 January 2007 at 7:42 PM
omg im so dumb...the lighting on the picture of the skirt is quite dark and i see there is a slit on the side.duhhhhhh sorry * blushes*
Maveris posted Sun, 04 February 2007 at 3:20 PM
Hi ComplexDarkness and trav,
Sorry for delay... :(
The miniskirt was tested in P4, PP, P5, P6 and P7 and the automatic JCM works.
You need to load V3 as a first figure in the scene then:
The miniskirt automatic JCM's (to apply the right rotation like twist, bend and side) need to read the character (V3).
Hope help you and have a nice day, Mav :)
P.S. Sorry for my poor english
Letterworks posted Sun, 04 February 2007 at 8:06 PM
Mavris
Retested per your instructions and yes the JCMs do work. Sorry if you felt I was making bad press on your freebie! I think you make some of the slickest free stuff out there, more exactly they are every bit the quality of most items sold in the market place!
BTW even loaded incorrectly the morphs worked more than adiquately by hand, so I would have been satisfied byt that alone.
mike
Maveris posted Sun, 04 February 2007 at 8:14 PM
Hi trav,
Don't worry... it's my fault... I need to write more instructions about  "How To" next time ;)
Have a nice day, Mav :)
Unicornst posted Sun, 04 February 2007 at 8:33 PM
As for the "wifebeater" shirt in the first image..... just dial down V3's breasts some. That should take care of the pokethrough on it. Use a dial like Breast2 or something. Or if it is a morph, look for the one that makes them larger than default and dial it down or set it back to 0.
