Subject: Silly Question: Rendering Figure as a WireFrame Model in Poser 6
ChromeDemon opened this issue on Jan 31, 2007 · 6 posts
ChromeDemon posted Wed, 31 January 2007 at 4:33 AM
I am trying to find the right setting to render out my Figure as a Wireframe Figure ... Only can find Sketch,Cartoon and the usual stuff ... I only can see my Figure as Wireframes in my Preview Window
any help is much appreciated
cheers
ChromeD
PhilC posted Wed, 31 January 2007 at 4:55 AM
You effectivly make a movie of a single frame with the render settings set as the Preview Window.
Hope this helps.
Jules53757 posted Wed, 31 January 2007 at 6:29 AM
As an alternative you can use the seams guide as texture and render as usual.
Ulli
Saluki posted Wed, 31 January 2007 at 8:09 AM Online Now!
Quote - - Set the display setting to Wireframe.
Hope this helps.
I'm not 100% certain (can't check right now) but could you not also do this using "Preview" in normal (single-frame) render settings?
adp001 posted Wed, 31 January 2007 at 9:29 AM
If you want anything wireframed, just make a "copy to clipboard" (Main Menu -> Edit -> Copy Picture).
The content of your preview window is copied to the clipboard and can be pasted in your prefered paint program.
kromekat posted Mon, 05 February 2007 at 9:12 AM
Yes, it doesn't need to be rendered as a single frame movie clip, you just select the Preview renderer from the render settings, and check antialiasing there. Document render size is then controlled via the usual dialogue.
Adam :)
Adam Benton | www.kromekat.com
