Subject: MorphManager 4.0
Gem_719 opened this issue on Apr 08, 2001 ยท 7 posts
Gem_719 posted Sun, 08 April 2001 at 11:04 AM
Just got it. Pretty neat! Trouble was, I needed it for a .hr2 and I needed it to re-order my morph targets. Neither is supported by the product. pout I was able to get around the .hr2 problem by renaming the file using a .cr2 extension. I know, I know, dangerous. But, hey, it worked! Now I need to know if there is an easier way of re-ordering the morphs than loading a copy of the original .hr2 (no new morphs) in the right window and then transferring the new ones from the disorderly .hr2 in the left window, in proper sequence. Hopefully there is cuz I have thirty. Using a drag-and-drop method would be great, but MM does not seem to support it. pout again The zip file for MM did not have an email for the product's author, so I'm hoping someone here will have an answer. I dunno, maybe I'm just lazy, but, THIRTY! ;o)
bloodsong posted Sun, 08 April 2001 at 11:56 AM
heyas; mr x's email is there if you press the help/about button. i use john stallings' cr2 editor to do this type of thing. it opens all poser library files, and you can drag the morphs up and down in the tree to drop them where you want. it takes a while, however. especially since you can't scroll up/down while you are dragging. the cr2 edit (or 'poser library file editor') is in the free stuff, here. make sure you get version 1.51 not 1.52.
Mason posted Sun, 08 April 2001 at 2:47 PM
I wrote MM. I was thinking of putting in a reorder thing but then thought about how people would want this. Do they want alphabetical? reverse alpha or would some pick list that selects the order be ok. I also stopped work on it since post of the functionality can be done in Poser Python.
Mehndi posted Sun, 08 April 2001 at 9:22 PM
If one could drag things upwards and downwards down the list, and have it drop into the order one "drops" it with the mouse, it would make organizing morphs by type alot easier :)
Petunia posted Mon, 09 April 2001 at 12:51 AM
Mason, don't stop work on your wonderful program, as not all of us really need or want the PPP. Your morph manager is totally cool! So thank you!
Dave posted Tue, 10 April 2001 at 12:17 AM
I agree. Keep up the good work. Any future features would be a godsend! Dave
wal posted Tue, 10 April 2001 at 7:37 AM
I'm using MM V4.0 on a Mac with the "Virtual PC"-Emulator. Works just fine! A re-ordering-tool, working in the way as Mehndi mentioned it, would be a great addition! So, please keep on working on MM, Mason. Even if I had the money to buy the PPP, I couldn't get it, cause the German version isn't available yet. ( A big :-( to CuriousLabs, which is a part of a German company (egisys), AFAIK! ) - wal
