Forum: Carrara
Subject: Replicator
traeumerle62 opened this issue on Feb 03, 2007 · 6 posts
traeumerle62 posted Sat, 03 February 2007 at 6:45 PM
Hi  I am new with Carrara and I have a question about the replicator  why they don't sit properly behind each other? Is there any possibility that I can change the pose of my fist vicky after the replication?  thank you :-)
MarkBremmer posted Sat, 03 February 2007 at 7:07 PM
Hi traeumerie62, What do you mean "not sit right"? Did you want them to line up in a grid? Mark
traeumerle62 posted Sat, 03 February 2007 at 7:43 PM
yes I think that is that what I want ...sorry for my poor english and your quick answer :-)
bwtr posted Sat, 03 February 2007 at 8:17 PM
I have done an exersize using the settings that I can read from your print screen save.
I have no problems in all items being uniformly spaced--without gaps.
Try a simple object, at the same settings and see if you get the same problem.
bwtr
MarkBremmer posted Sat, 03 February 2007 at 11:11 PM
Hi traeumerie62, I too get things to show correctly. :-/ Try this, hide your original object (uncheck the visible button) The original object does not need to be visible to replicate. When you hide the original object, all you will see is the replicated grid. You may be seeing the original object plus the grid whic makes things look strange. No apologies on the english! ;-) Mark
traeumerle62 posted Sun, 04 February 2007 at 5:30 AM
thank you very much both ... I will try again :-)
