Carolyn5799 opened this issue on Apr 08, 2001 ยท 3 posts
Carolyn5799 posted Sun, 08 April 2001 at 3:18 PM
I purchased the Buck from DAZ and cant get it to work. Where should I put the buck files? It shows up in the library thumbs but when I click on it it says I dont have enough memory. Carolyn
shadowcat posted Sun, 08 April 2001 at 10:43 PM
The files should all be where they need to be, Daz autoloads to the proper locations (mostly anyway) if it is showing up in the library, then yours did. Maybe the .rsr is corrupted? go to c:program filesmetacreationsruntimelibraries"folder Buck is in" and delete the .rsr file assosiated with the Buck (don't worry poser will rebuild the .rsr file) if you continue to have problems contact DAZ
hauksdottir posted Mon, 09 April 2001 at 5:46 AM
Carolyn, Poser really needs a lot of memory to work well, especially if you add lots of textures or have a complicated scene with several props or people. I'm giving it 200 Megs (of the 384 on this system)... on the advice of Zygote/DAZ... and the program has run pretty happily since. Please check to see how much memory you have on your computer, and allocate to Poser more than the "suggested" amount if you can. (One and a half times that is recommended for many programs.) (This is easy on the Mac, I'm not sure how you do it on a PC.) Also, try not to have other memory hogs (such as PhotoShop) running at the same time. Hope this helps! Carolly
