pzrite opened this issue on Feb 19, 2007 · 5 posts
pzrite posted Mon, 19 February 2007 at 11:43 AM
I tried Windows Vista and realized that it seriously slowed down all my 3D apps, so I ditched it and reinstalled Windows XP. After a days worth of reinstalling programs, everything works EXCEPT for Poser!!! I reinstalled Poser 7 three times and everytime I try to open it, I get the Windows error message "Program needs to close - Error".
Poser will get about 20 seconds into the startup screen and then crash. I also had Poser 5 and 6 installed and they all do the same exact thing! I really can't figure this one out.
Some clues as to what is happening: Poser did initially run after I reinstalled, but when I tried to open some existing files I would have to manually search the runtimes for files because the Drive Letter changed after the reinstall of Windows. Then when I tried to resave a Poser file, the file would end up being BLANK, with a file size of zero!
So then I tried using Dimension3D's Runtime Repair (which seemed to be repairing the path references) and that's when Poser completely stopped working!
I'm not saying that Runtime Repair is the problem, I think it just might have made worse an existing situation.
Thanks for any help!!!!
nruddock posted Mon, 19 February 2007 at 2:27 PM
Did you remember to reinstall the latest drivers for your video card ?
Stan57 posted Tue, 20 February 2007 at 12:49 PM
Do you have the downloaded installer or a CD. If you have the downloaded installer i would redownload poser 7 it may have been corrupted with the install of Vista. Also make sure you install all of Win XPs updates,including SP2
Jack Of All Trades Master Of None
pzrite posted Thu, 22 February 2007 at 8:09 PM
Thanks for your suggestions:
Problem solved! I uninstalled Vista and reinstalled XP. It was slowing down Carrara, Vue and anything else that used OpenGL. Anybody want to buy a used copy of Vista? (just kidding - I'm going to use the disc as a very expensive coaster)
Just FYI, I used "Dr Hardware", a hardware monitoring device, it benchmarks your machine and compares it to other similar systems. With Vista, running my graphics was compared to a Pentium 2 machine. When I put back XP, it was right back where it belonged, P4 with 2 gigs of RAM. Did I mention I HATE WINDOWS VISTA!
Stan57 posted Fri, 23 February 2007 at 2:30 AM
I dont have a problem with slowness and i use Carrara,Poser i have a P4 3.40Ghz w hyperthreading and 2 gigs of ram. I have a Nvida 7800GS Vid card and i am using the current beta drivers.
I had the highest score 5.9 for graphics and overall a 4.3. I do have some problems with poser 7 but i had problems with 7 before i moved to Vista Ultimate. I also get, this program is not compatable with aero but it just shuts it off for the program, its PSP 8 and Corel PSp XI but i have stardock window blinds and the same 2 programs i had to exclude from the themes.
I like Vista Ultimate, sure it has bugs but i dont remember one microsoft OS release that didnt have bugs or anyother OS for that matter. Over all for my system its pretty darn stable. :)
