RedPhantom opened this issue on Feb 19, 2007 · 7 posts
RedPhantom posted Mon, 19 February 2007 at 7:55 PM Site Admin
I'm wanting to make a ghost. Is there any to make an entire figure transparent? I tried using the material room, but when I did that you can not only see the body through the clothes, but also can see the eyeballs and teeth through the skin, even though I made them transparent too. Is there another way to do it? I'd rather not have to fudge it in psp.
kayjay97 posted Mon, 19 February 2007 at 8:50 PM
Attached Link: http://market.renderosity.com/mod/bcs/index.php?ViewProduct=40771&vendor=339517
Fallen Angels, Restless Wraiths by Cyllan here inthe MP is pretty coolIn a world filled with causes for worry and
anxiety...
we need the peace of God standing guard over our hearts and
minds.
Jerry McCant
David.J.Harmon posted Mon, 19 February 2007 at 9:05 PM
(Fallen Angels, Restless Wraiths)
thank you for the info.... I think I can put this to good use.
has anyone used it for P7
David J Harmon
davidjharmon.com
Angelouscuitry posted Mon, 19 February 2007 at 11:04 PM
Yu could just go into the Material Room; set one part of a figure's Diffuse Color to white(Without any Textures,) then that parts Transparency to about 80-90%, and then use the Apply to All feature, near where you create a new node from, in the top right of the Node Palette. You'll probably need to set internal parts, like Teeth, Tongue etc to %100 transparent.
An other option is to just render as usual, and then alter the Opacity of your figure in a 2D Image Editor, like Photoshop.
Miss Nancy posted Mon, 19 February 2007 at 11:17 PM
if modern conceptions of ghosts are related to "manifestations" in the 19th century by parlour charlatans, or by cinema depictions in the 20th century, then the easy way to do it is to map a render (or movie) of the character onto a 2d-prop, then vary the transparency of the prop in the poser scene. however, I would encourage one to purchase those items mentioned above.
YngPhoenix posted Tue, 20 February 2007 at 2:02 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2670014
RedPhantom, you could check out the link above(it's a little more work but free).slinger posted Wed, 21 February 2007 at 7:34 PM
I've got a set of textures I made for the PlanIt 3D Christmas give-away. You might find a couple of them would work for you.
You can get them here
Here's a render of the first in the series....
They're all P6 procedural textures, so the whole package of 12 textures only weighs in at 145 KB zipped.
The liver is evil - It must be punished.
