FargoJ opened this issue on Feb 23, 2007 · 5 posts
FargoJ posted Fri, 23 February 2007 at 2:07 AM
Hello all :-)
I've been having this problem for several days now, as you can all see in the following examples, the M3 body morphs fail to apply in the left arm, and left leg, I don't know how this can be, and I honestly don't know how the problem began, even if I try to apply the morphs individually to those parts, they just won't work, even if the correct dials are there! I doubt that I might be missing any files, since I inspected them myself in my Poser 6 folder, and everything's there, I even tried to re-install the M3 base along with it's body and head morphs, but that doesn't seems to solve anything, has anyone around here stumbled across a similar problem? and if so, how can this be fixed?
Thanks!
Acadia posted Fri, 23 February 2007 at 2:47 AM
This is a common problem. Go back to Daz and reset your downloads. Then reinstall M3 and all of his morphs and it should work.
say." - Ghandi
jugoth posted Fri, 23 February 2007 at 7:43 AM
I had old m3 morphs and downloaded again the improved morphs had no trouble, though have not checked again, what you could do is download morphs again.
What i do is install 1 morph at a time and not all in 1 go, so if thier are 30 inj for him install 1 at a time.
Then save as do with all my characters.
RHaseltine posted Fri, 23 February 2007 at 9:33 AM
Make sure you don't have any older copies of the morphs or figure files in another Runtime (if you use multiples).
If your figure file is Michael 3 SR1 or Michael 3 SR2 then it's the morphs you need to reset, download and install - if not it's the figure itself that needs a new version.
FargoJ posted Fri, 23 February 2007 at 10:14 AM
Ok, thank you everyone for the help! I'll see what of these suggestions might work, and hopefuly my problem will be solved :-)
