jdenoma opened this issue on Feb 25, 2007 ยท 3 posts
jdenoma posted Sun, 25 February 2007 at 12:18 PM
I'm finding myself at the point of having a 15gig runtime and have clothing packages from various base models floating around. Since poser 7 can use multiple runtimes I was wanting to separate out my runtime into the base characters (Aiko 3, Victoria 3/4, Michael, etc) and have all the associated packages with that runtime so everything stays together. My question is this: Is there something out there (preferably for Mac) that will allow me to see the geometries that are associated with a specific item? (as I want to make sure I get all the associated files transferred over) I'm actually on a Macbook Pro, so I can use windows programs if necessary.
momodot posted Sun, 25 February 2007 at 2:07 PM
There is a product called Poser File Organizer that does all this sort of stuff but an easy way I use to check the geometry is to open the item in a powerful but simple text editor (editpad lite on my PC) and do a search for the string ".obj" or ".obz" which should take you right to the path for the geometry call.
Dajadues posted Sun, 25 February 2007 at 2:22 PM
I wouldn't recommend that. You shouldn't move or rename geometry folders & texture folders because if you do, then, you will have a major path problem.
I do mine by base characters without touching these folders & I have close to 30gigs of content to sort through.
