onefromb5 opened this issue on Mar 04, 2007 · 8 posts
onefromb5 posted Sun, 04 March 2007 at 10:05 AM
I keep getting an error message "cannot find DELTAS" when I try using certian character morphs ie power beauties, sensual beauties.
I do have the V3 morph packages.
Can anyone help with this?
RHaseltine posted Sun, 04 March 2007 at 2:00 PM
Which deltas? It's possible you have a pose that's calling for some of the expression morphs, which are now embedded in V3 and so have no real external delta and visibility files (though there should be empty files as placeholders). Do you have the International beauties morphs, or only a character or the texture packs? Are you sure everything is installed correctly - the installer pointed to a Poser content directory?
onefromb5 posted Mon, 05 March 2007 at 6:26 AM
yes i have the international beauties pack and im sure everything has installed properly.
RHaseltine posted Mon, 05 March 2007 at 8:25 AM
So which file or files can't it find?
onefromb5 posted Mon, 05 March 2007 at 5:17 PM
the morphs just wont load due to the error message"cannot locate deltas"
RHaseltine posted Tue, 06 March 2007 at 9:56 AM
Can you take a screen shot of the error screen? I haven't seen that one before.
SophiD posted Wed, 07 March 2007 at 8:31 AM
check in your Libraries folder for a directory named !DAZ and look for the Victoria 3 folde. if you have both Chanvis and Deltas in the folder then it should be ok. if not, maybe you deleted them by accident? or installed them into a different directory?
onefromb5 posted Wed, 07 March 2007 at 9:18 AM
i figured it out there is an inital morph pack i didnt dl in order to use them.
Thanks everyone for your help.
