Subject: IS THERE A WAY TO KEEP MY CONNECTION FROM TIMING OUT ?
sekhet opened this issue on Mar 05, 2007 · 4 posts
sekhet posted Mon, 05 March 2007 at 8:10 AM
Like the subject says, can I keep my internet connection from timing out, so I can download P7 ?
AMD 3600, 2gig ram, XP pro, IE6, DSL
Thanks
dadt posted Mon, 05 March 2007 at 9:48 AM
I would use a download manager so that if your connection times out you will be able to resume your downloading from where it stopped.
I use one called "Free Download Manager" Which I have found to be excellent.
Darboshanski posted Mon, 05 March 2007 at 10:01 AM
Hi..hopefully following may resolve the issue...
Click Start > Connect To > Show All Connections...
Select your Broadband account icon
Right Click > Properties
Click Options and under 'Idle time before hanging up'  check to see of it is selected to "never" of not then choose 'never'
Other options open to you is to fool around in the registry which I don't recommend  unless you have some experience doing so.
All the best!
My Facebook Page
jfbeute posted Tue, 06 March 2007 at 1:00 AM
It also depends where it times out. If it times out at the end you might have a problem with the combination of firewall and browser. Changing browser and/or the settings of the firewall might solve the problems.
