freefall565 opened this issue on Mar 07, 2007 ยท 6 posts
freefall565 posted Wed, 07 March 2007 at 10:50 PM
I was wandering if it is possible for walk designer to do stairs, or to make a walk path do stairs, or something along those lines without having to actually do the walk frame by frame? just curious if its possible?
Teyon posted Wed, 07 March 2007 at 11:21 PM
Check your library. There should be one in there already.
lesbentley posted Thu, 08 March 2007 at 6:22 PM
Don't know about P7, but I don't think there is any way in earlier versions to do walking up stairs.
Teyon posted Thu, 08 March 2007 at 6:35 PM
It's not in the Walk Designer itself and that's my bad for not being clear.
In the Pose library, there's a set of poses for stair climbing. Mixing them up can give you a solid jumping off point for an animation. You'd only need to go back and and do some tweaking here and there.
freefall565 posted Fri, 09 March 2007 at 11:41 AM
Thanx lesbentley, I actually am working in poser 6, so if you happen across how it is done, please let me know.
freefall565 posted Fri, 09 March 2007 at 11:42 AM
Thank you teyon, I'll give it a try and see if I can work it out.
