softcris opened this issue on Mar 12, 2007 · 3 posts
softcris posted Mon, 12 March 2007 at 5:52 PM
FILE ( source explanation name from:http://filext.com/alphalist.php?extstart=%5EF ) from Mac does not opens in PC Photoshop. I work with Mac and at home I have my PC.
So I had to work some at home..I use to work with in Photoshop Cs for Mac..at home I use same but CS2 for PC.
It only shows as: FILE! I can't open anywhere but ..*QuickTime Player obviously an Apple software. But I have 1000 thousand of those FILE files to work in Photoshop CS2 to make a bacht changing the extension to *.PSD or *.PICT both system understand those.
Now anyone with a briliant solution for it?
'Cause one by one in QuickTime Player I'll die before I end it.
THANKS in advance to a brilliant cerebral
softcris
"'you shut up! or I'll
bring democracy to your country! "
Cris
Galvão aka Softcris - www.crisgalvao.com
(or softcris,
SoftCris)
Rendering since 1997 and
at Renderosity since 1999.
OS
Win 8.1 64 bit
retrocity posted Mon, 12 March 2007 at 11:06 PM
hope this helps!
retrocity
and remember "Friends Don't Let Friends Do DOS!! "
thundering1 posted Tue, 13 March 2007 at 8:36 PM
The general word "files" doesn't necessarily describe what you're trying to load.
It's very possible that in the file names the extensions didn't save - in which case don't make the extension.psd when it is a .tif - you get the idea?
Try this - instead of copying a whole "folder", make a copy of all the images (not in a folder but loose) on a CD, and just copy them onto the HD.
If the extension is not on the files on the CD, then type them in just looki9ng at the folder - not in Photoshop, but just open the folder they're now in, and right-click, choose Rename, and at the end type ".***" (whatever the extension is - jpg, tif, psd, bmp, pict, tga - get the idea?)
Basically, if you name it a .psd, and it is a tif, Photoshop STILL won't know what it is opening, or can't open it because that's not what it really IS (it's looking for a specific codec and it's actually another).
good luck - hope this helps-
-Lew ;-)
