Forum: Vue
Subject: SideBySide errors found in system event viewer
ShawnDriscoll opened this issue on Mar 13, 2007 · 14 posts
ShawnDriscoll posted Tue, 13 March 2007 at 2:23 AM
It happens when I run Vue 6 Infinite on my XP32 SP2 system on my 2.26GHz P4.
What is SideBySide?
thefixer posted Tue, 13 March 2007 at 3:27 AM
I reported this an many other messages in event viewer and was told "it doesn't matter, it's not important"
What they are and what they mean I have no idea!
Injustice will be avenged.
Cofiwch Dryweryn.
Roger6794 posted Tue, 13 March 2007 at 11:26 AM
SidesBySide is part of the Microsoft Visual Studio development tools for C++ (and perhaps the other programming languages as well).
I once encountered a lot of SBS errors saying SBS was'nt correctly installed. Some progs did'nt react after starting and all my application log was full.
After I installed the C++ V8 redist package (you can obtain it from MS download), I do'nt have problems any more.
keenart posted Tue, 13 March 2007 at 12:23 PM
Yeah! I just spent the last two weeks with an MS tech, because my Temp folder is filling up with Log files.  The tech finally said, "Not important, it is the way the system logs its activity.?!"
It never did that before!  Is this some kind of new check your computer activity by MS?
jankeen.com
Roger6794 posted Tue, 13 March 2007 at 2:58 PM
Quote - ...  Is this some kind of new check your computer activity by MS?
No, this portion of SBS is written by Seagate. The purpose is filling the harddisk ;-)
keenart posted Tue, 13 March 2007 at 6:37 PM
Shame on Seagate.  I thought three harddrives were enough!
jankeen.com
ShawnDriscoll posted Tue, 13 March 2007 at 9:04 PM
Quote - SidesBySide is part of the Microsoft Visual Studio development tools for C++ (and perhaps the other programming languages as well).
The error is:
Generate Activation Context failed for C:Program Filese-on softwareVue 6 InfiniteModulesMicrosoft.VC80.MFCMFC80.DLL.
So I'll try the C++ v8 redist pack and see.
Roger6794 posted Wed, 14 March 2007 at 4:02 PM
If that doesn't work, here's a description to fix the problem manually:
Though there are no runtime errors,there might be errors in event viewer** like Component identity found in manifest does not match the identity of the component requested Syntax error in manifest or policy file
"C:ClientMicrosoft.VC80.MFC.MANIFEST" on line 4. Generate Activation.Context failed for C:Clienttest.dll. Reference error message: The operation completed successfully
There are 2 bugs which cause this.
  1. The assembly manifest of Microsoft.VC80.MFCLOC is incorrect. It has version 8.0.50727.42 instead of 8.0.50608.0.
Solution
Change the version number
should be changed to
  1. Microsoft.VC80.MFCLOC is referenced not by the application but by MFC80[ud].dll
    Solution
    Microsoft.VC80.MFCLOC directory has to be under Microsoft.VC80.MFC directory and not at the same level.
Aldaron posted Wed, 14 March 2007 at 4:16 PM
Does anyone have a link to the C++ V8?
I get the above errors everytime I try to load a model from the extras CD and it crashes Vue6.
I run WinXP64 and have the digital version of Vue6Inf so I have the ExtrasCD zip file instead of the Extras CD1 CD.
Roger6794 posted Thu, 15 March 2007 at 4:19 AM
I've attached the redist file as a .zip
I hope that works.
regards,
Roger
No, didn't work. Had to search ms-download. Here's the link:
http://www.microsoft.com/downloads/details.aspx?FamilyID=32bc1bee-a3f9-4c13-9c99-220b62a191ee&DisplayLang=en
It's newer than the one, I used but I think that does not matter.
Roger6794 posted Thu, 15 March 2007 at 4:42 AM
Here's VC++ redist X64 link
http://www.microsoft.com/downloads/details.aspx?FamilyID=90548130-4468-4bbc-9673-d6acabd5d13b&DisplayLang=en
Aldaron posted Thu, 15 March 2007 at 10:32 PM
Thanks, tried that one and some of the models still crash Vue6, not all but some of them. Models without the CD symbol and those that are imported work fine but some with the CD symbol simply crash Vue6 and when I look at the event logs it says Side by side. :(
Roger6794 posted Fri, 16 March 2007 at 3:39 AM
Aldaron,
the side by side error is not a unique one, but a class of errors. The more important information follows the SBS error. Paste the error description and the name of the scene here, perhaps we can see what is causing it.
btw, did you install the update for VUE Inf 6 ?
regards,
Roger
Aldaron posted Fri, 16 March 2007 at 12:31 PM
That's just it, I have no other errors in the event log that go with that. After that happens it's just normal events.
I guess it's not much of a big deal as it's only certain models from the Extras that don't work, I can always find other models to import.
As for the update, if you mean the beta update, no. I'm waiting until it's out of beta to apply it.
Thanks
