vernonglen opened this issue on Mar 22, 2007 · 5 posts
vernonglen posted Thu, 22 March 2007 at 10:12 PM
I am using Carrara 6. 5.1.0.57 on an Intel chip Mac. I am a long time Carrara user, but I am unable to create multiple sections on Spline Objects as I used to. I select the one section at the near end and then select "create multiple" as before, but nothing happens! What am I missing??? The Carrara help area is not helpful here..
Please advise, I must be missing something obvious.
Thanks gang,
Vernonglen
MarkBremmer posted Thu, 22 March 2007 at 11:30 PM
If I understand your post, you are selecting a cross section you made at the end of the extrusion. Select the first cross section instead, not the last. You can also select and create multiples from any cross section except the last one.
bwtr posted Thu, 22 March 2007 at 11:31 PM
Carrara6???. Guess a wishfull miss type. The Windows version is simply 5.1 so it maybe is a Mac thing.
bwtr
Tashar59 posted Thu, 22 March 2007 at 11:39 PM
Too funny, I went and checked Daz to see what I missed too.
vernonglen posted Sat, 24 March 2007 at 1:19 PM
Thank you,
Choosing the first crossection does allow me to create multiples.
You all caught me, I am using Carrara 5.1.0.57 (what a lot of versions!)
Maybe I confused it with Bryce 6 which I also use a lot.
Thanks again, for the help. Virtual life is good.
vernonglen
