tebop opened this issue on Mar 25, 2007 · 8 posts
tebop posted Sun, 25 March 2007 at 3:44 PM
And how would you do it,,,... . AM i correct in this method? : 1. save 2 different poser files with 2 different poser characters as 3ds or OBJ. 2. Open Vue, and go to your Object libraries and ADD new collection and search for the folder containing those 2 files. 3. THAT's it. use them in ecosystems is that right? And if i make an ecosystem of 100 poser characters, will it work or crash my system?
thlayli2003 posted Sun, 25 March 2007 at 4:48 PM
That should work. Crashing will depend on your system. I have a meager system and can easily handle crowds of up to 100. If you use Poser files directly, I think there may be some issues. I don't use Poser, but I do use exported 3ds and OBJ from other software.
chippwalters posted Sun, 25 March 2007 at 8:52 PM
I would recommend opening up your poser figures directly in Vue and then save them as Vue vob's, not 3ds or OBJ.
tebop posted Sun, 25 March 2007 at 10:04 PM
Oh ok. .great idea. So i convert them to VOB . i didnt know that. thanks alot
thefixer posted Mon, 26 March 2007 at 2:11 AM
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=1337686
Another way to do crowds depending on the use is to make an Alpha plane image in Poser and then use them on billboards in Vue, you can add thousands this way for little cost in resource. The only down side is repetitiveness, you need to do a few Alpha pictures to get variations. This "army" of Sci-Fi soldiers was done in this way!Injustice will be avenged.
Cofiwch Dryweryn.
BernieStafford posted Mon, 26 March 2007 at 3:40 AM
Yes you can - here's an example of just that:
http://www.renderosity.com/mod/gallery/media/folder_141/file_1406452.jpg
I imported each pz3 individually into V6I, making sure that "use Poser shader" & "re-pose within Vue" were NOT ticked, then saved as a .vob. I used about 6 - 7 different figures in order to make the crowd look random.
The crowd on the walkway is an eco-system applied to a plane, the group on the left was created using the paint eco-system function.
One final point - materials from Poser often do not load correctly into Vue, so expect to spend some time fine-tuning before you save the finished object!! :-)
silverblade33 posted Mon, 26 March 2007 at 8:24 AM
http://www.silverblades-suitcase.com/vue1/legion_final.avi
uses DIVX format
I've been working on somehting, sicne it's going to have many diffferent figures I optomized it a lot.
-Used as many of the same materials as possible across all figures, each material takes resources, if they cna share same material that helps.
-I used michael 1 reduced figure, so much less polys, deleted body parts that wouldn't be seen on each figure.
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
tebop posted Mon, 26 March 2007 at 8:28 AM
Great tips guys
