Ganajin opened this issue on Mar 26, 2007 · 6 posts
Ganajin posted Mon, 26 March 2007 at 12:39 PM
I have a problem with Vicky 4 that seems rather unusual. Occasionally, when moving her around or bending or twisting the neck, her teeth, gums and tongue-base, will be left behind, floating in mid-air. Not only that, but their behaviour seems pretty erratic. Sometimes nothing will happen, at others they will pop out of her head at the slightest provocation.
Now I am guessing that this has something to do with parenting, but exactly how or what I do about it just beats me. Is this a problem I am having alone (faulty installation perhaps) or has anyone else noticed it?
Ghostofmacbeth posted Mon, 26 March 2007 at 12:48 PM
"Point at" seems to ruin the teeth for some reason. If you don't use it you should be fine.
Ganajin posted Mon, 26 March 2007 at 12:54 PM
Do you mean pointing the teeth themselves at something (pretty weird) or just using Point At at all?
Ghostofmacbeth posted Mon, 26 March 2007 at 1:51 PM
Usually I have heard of it messing up after using point at with the eyes.
Ghostofmacbeth posted Mon, 26 March 2007 at 1:52 PM
Just saw this at another site "One way I found to put the teeth in place is after you have the eyes point at a camera, and posed the head any way you want. Once you done that, select the upper jaw, or lower jaw and then hit CTRL+E, and this will put the jaws back in the figures head, aligned with the position of the head. Hope this helps."
Ganajin posted Mon, 26 March 2007 at 4:51 PM
Very helpful indeed. Many thanks.
