Subject: Heirarchy Editor and Shadow Maps Question
Elfwine opened this issue on Mar 27, 2007 · 5 posts
Elfwine posted Tue, 27 March 2007 at 1:43 PM
Question: If you use the Heirarchy Editor to switch off the visability of body parts to avoid poke through (for example; you put a body suit on a figure), will Poser still render shadow maps for those parts? If you select say, a single body part, and select "Properties" from the Menu, a dialog box appears about that part which let's you uncheck the "Visible" and "Casts Shadow". So I was wondering if you changed the visability using the Heirarchy Editor, does the editor also turn off the 'casts shadow' for that part?
 Don't sweat the petty things, and don't pet the sweaty things!  ; )
adp001 posted Tue, 27 March 2007 at 2:23 PM
Switched off objects are completly ignored by the render engine.
markschum posted Tue, 27 March 2007 at 2:58 PM
its an easy experiment , put a figure in and a prop square , set a light to cast a shadow on the square turn visibility for say the chest and see what shadow you get .
Elfwine posted Tue, 27 March 2007 at 5:19 PM
ADP, thank you markschum, good point! ..hadn't thought of that
lesbentley posted Tue, 27 March 2007 at 6:16 PM
ADP is correct, it is sufficent to turn off visability, you don't need to turn of  Casts Shadow as well.
