richcz3 opened this issue on Mar 30, 2007 · 5 posts
richcz3 posted Fri, 30 March 2007 at 3:28 PM
I have a work flow that definately needs an Action for batch processing. I need to insert a Safe Area layer as the top layer in a PSD. The Safe Area layer has multiple layers that are in a folder that need to remain editable. So copy/paste functions aren't the solution.
I'm using CS2 - Anyone have any ideas.
Thank in advance.
nattarious posted Fri, 30 March 2007 at 4:35 PM
Hello Rich..
You might wanna check this LINK
Also you might wanna check this one too: LINK
Thank you and good luck
JOE
NATTARIOUS[C] IS A WELL KNOWN INTERNATIONAL CLUB DJ - PHOTOGRAPHER - GRAPHIC AND COMMERCIAL DESIGNER AND THE OWNER OF XOOM STUDIOS PRODUCTIONS & CERTIFIED LEGAL GOLD MICROSOFT PARTNER!
XOOM STUDIOS PRODUCTIONS® OFFICIAL WEBSITE: WWW.XOOM-ARTS.COM
XOOM STUDIOS PRODUCTIONS® Ultimate Web Templates Just Click
It
richcz3 posted Fri, 30 March 2007 at 5:44 PM
Hi Joe - Thanks for the links.
I have about 8 Actions I've made over the past two weeks that have saved allot of production time.
Where Action features appear to come short is opening multiple PSD docs and Inserting one into another. Imagine manually inserting hundreds of PSD layered files in a deadline. Yikes!
Inserting layers by "dragging" is not recorded in actions. It just shows documented selected. I've tried the "Open" action (folder location) but having two "Layered PSD" files interact with each other is where the limitation appears to be.
I'm sure there's a work around here somewhere.
SWAMP posted Fri, 30 March 2007 at 10:15 PM
Attached Link: http://www.avbros.com/english/collector/index.html
Here is a free script (link) that will insert multiple documents into one (each on their own layer). Photoshop has it’s own script that will do the opposite “Export Layers To Files”. So you could use the PS script to break up your layered PSD’s and export to a folder…. Then use the “collect script” to grab them and layer them into your new document.Don’t know if you can record a running script as an “action” (for batch processing) ..never tried it.
Might try asking over on Adobe’s Photoshop Scripting forum for something better…(some of those guys love to write scripts).
SWAMP
richcz3 posted Fri, 30 March 2007 at 11:58 PM
SWAMP - Wow that looks as close as possible to what I am looking for. It may just do the trick. It looks like allot of options can be keyed in . I think you're right I do not believe a script can be built into an action, but this script alone could more than offset the current drudgery. I'll give it a run and see how it goes. Thanks again. **
