FrankT opened this issue on Mar 31, 2007 · 4 posts
FrankT posted Sat, 31 March 2007 at 2:06 PM
I've exported a scene from Poser as a RIB file and the render engine is having a hell of a job with it - keeps saying there's a problem with the textures in one of the shaders. Poser is also putting [ ] brackets in where it shouldn't by the looks of things.
Does this export actually work ? is it worth me fiddling around with the RIB file or should I stick to Firefly/POV-Ray ?
Yours in confusion
Frank
replicand posted Sat, 31 March 2007 at 5:40 PM
For P6, I have no known issues with RIB export. Theoretically there shouldn't be a problem with textures since textures / shaders would need to be applied with some sort of RAT (compliant) tool.
FrankT posted Sat, 31 March 2007 at 8:30 PM
From what I have managed to figure out so far, the export has broken the pathnames to every single texture in the file by removing some or all of the backslashes - and not the same ones each time either
sigh
FrankT posted Sat, 31 March 2007 at 9:06 PM
and most of the geometry is missing too
