danway opened this issue on Apr 04, 2007 · 7 posts
danway posted Wed, 04 April 2007 at 7:36 PM
Peggy_Walters posted Wed, 04 April 2007 at 8:13 PM
Lens glare turned on for the sun or maybe a light has a flare set on?
LVS - Where Learning is Fun!
danway posted Thu, 05 April 2007 at 11:01 AM
No lens flare or lens glare used. It's a shadow setting or something similar. When I turn off shadows it disappears. Any suggestions?
Peggy_Walters posted Thu, 05 April 2007 at 1:23 PM
Have you tried just a quick render using the Final settings? I would also try a test render using a different atmosphere.
Please list what version of Vue you have and if the latest patches are installed.
haegerst posted Thu, 05 April 2007 at 1:39 PM
The image you posted is so small, i can barely see anything. Can you render a test image a bit larger, that would make it easier to spot any problems i guess.
Vue content creator
www.renderarmy.com
danway posted Thu, 05 April 2007 at 8:12 PM
I have done a final render with everything turned up all the way and the spots are still there. I'm using the final release of Vue 6. I'm working on another test render, I will put up a larger pic of the problem area when it's finished. please check back shortly.
danway posted Thu, 12 April 2007 at 7:05 PM
Please disregard this post, I got frustrated and started over. Trashed the original file.
