Forum: Bryce
Subject: For Fran and anyone else interested. Small fire tut
draculaz opened this issue on Apr 05, 2007 · 14 posts
draculaz posted Thu, 05 April 2007 at 4:20 PM
Greetings and salutations. In case you're wondering how to create fire in Bryce 5, 5.5 or 6, the answer is: easy.
You have two choices:
In the attached image the fire is actually a supernova from NASA for the explosion mapped on a sphere. So go nuts, it's just a matter of finding the right image off Google or taking your own.
drac
Death_at_Midnight posted Thu, 05 April 2007 at 4:57 PM
Don't forget the environment effects upon the fire. Such as the vacuum of space might not generate a lot of flame (O2 or other gas to feed a flame), but there might be more sparks. Low gravity or 0G might render a spherical explosion such as a "sun burst" nuclear explosion.
draculaz posted Thu, 05 April 2007 at 5:00 PM
what he said :)
ellocolobo posted Thu, 05 April 2007 at 5:52 PM
Thanks Drac...Good to see you again...
pakled posted Thu, 05 April 2007 at 8:56 PM
now that's pod racing..;)
AgentSmith posted Thu, 05 April 2007 at 9:35 PM
I've had *some* luck with using photographs of fire to make actual volumetric Bryce materials. Trick is, you always have to wrap the texture Random, or it looks strange. Then its just a roll of the dice on how the result will look. Some are cool, yet a lot just don't work quite well, it all depends on the photo.
Sophies posted Thu, 05 April 2007 at 10:53 PM
This is a testrender of some fireflames i  made in skylab. They where rendered and then reimported on a 2d plan. The flames looks realy nice in the original render. Skylab it's a good thing   :)
bikermouse posted Fri, 06 April 2007 at 2:04 AM
Ah, Yes - Skylab! Very good idea!
TheBryster posted Fri, 06 April 2007 at 7:00 AM Forum Moderator
There are some flame pics in the downloads section of my website............
sackrat posted Fri, 06 April 2007 at 7:13 AM
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=1179900&member
What about menno fire, by, uhhh , menno (see attached link), don't know if it's still available or not, but it was used in the linked image and was very easy to work with. Just a thought.
"Any club that would have me as a member is probably not worth joining" -Groucho Marx
Analog-X64 posted Fri, 06 April 2007 at 8:27 AM
I did some searching...and couldnt find anything by the name menno anywhere.
sackrat posted Fri, 06 April 2007 at 8:33 AM
Bummer !
sackrat posted Fri, 06 April 2007 at 8:34 AM
I've still got it,...........and it was a freebie. Lemme' know if you want it.
Death_at_Midnight posted Fri, 06 April 2007 at 10:56 AM
I use one that was in a freebie section somewheres... it's listed as primordial fire. Comes in a set of like five or six.
