adp001 opened this issue on Apr 07, 2007 ยท 42 posts
adp001 posted Sat, 07 April 2007 at 6:22 PM
The last week I wrote a program able to extract joint parameters from an CR2 file and save them to a standard posefile (PZ2), even "partial". So, if you're somebody playing with the joint parameters of a figure, this program is for you.
Because a Python script isn't able to access the parameters of a loaded figure from within Poser, you have to save your figure with modified joint parameters as a CR2 file first.
I used it to make a collection of joint poses (JPF = Joint Pose File) for several figures. Full and partly. A lot of bending problems are easily to fix for me now. I just have to attach a Joint Pose the same way I do with any other pose :)
Because the program does not use Poser Python it doesn't matter wether you are using Poser 4/5/6/7 or D|S. Just start the Installer and anything needed is installed automatically. No worries about allready installed packages, libraries, whatever.
This version is free for a limited time. Download it from here.
