Wizardkiss opened this issue on Apr 13, 2007 ยท 9 posts
Wizardkiss posted Fri, 13 April 2007 at 6:10 AM
I was delighted to see that a PLE version of Vue is now available but I'm having some trouble with moving the camera around.
When using the mode they call "rotate camera" in the options (as would often be called "mouse-look") it works in reverse of the way every other 3D application or game I've used works. Moving the mouse left moves the view right, up moves it down, and so forth. Is there an option to invert the mouse-look movement?
Is there a key to move the camera continuously forward to complement the mouse-look style of camera movement?
Is there a way to pan in the 3D main camera view without having to use the icon in the little camera controls window? There is an option to set the pan controls in the key config but it only seems to work in the 2d views.
I've looked through the manual and am doing searches for the answers to these questions but no luck so far.
