Ares_Designs opened this issue on Apr 23, 2007 · 3 posts
Ares_Designs posted Mon, 23 April 2007 at 1:18 PM
I have been going thru the manual that comes with P7 and have stumbled on something that either I am missing or it is not in there. Now bare with me as this may be hard to explain/put in a question.
When you first load a figure in to the workspace say V4 and in the Parameters/Property tab menu it allows you to change the figure name ie from Victoria4 to "whatever" . Now lets say for arguments sake that I call the figure Doris, I use selected morphs, mats and such. After adjusting to taste it suits what I need. I know I can save it has a pz3 file. But can the figure itself be saved as Doris?
I ask becuase of working on a comic and other things I would be able to save time by just loading V4/Doris instead of loading V4 and one by one recreating her or even "destroying" the first created scene to just use Doris again.
I hope that makes sense.
Thanks in advance
SSAfam1 posted Mon, 23 April 2007 at 1:26 PM
Why not save Doris to your figures library and set her to your preferred state. That way she will load automatically upon startup?
Angelouscuitry posted Mon, 23 April 2007 at 1:57 PM
Yes, open the Figures library, and click on the "+" button. Where you save her, in your Figures library, is indicative of what the directory structure of your:
C:Program FIlesPoser InstallRuntimeLibrariescharacter
folders' looks like.
You'll be saving a .CR2, which is just the Poser charcter and/or anything parented/conformed to her. You'll need to give the .CR2 file another name, but you can use Doris again; and then when you load that .CR2 into a new scene, the Properties tab will still say Doris(regardless of what you named the .CR2)
