whirlwind opened this issue on Apr 27, 2007 ยท 3 posts
whirlwind posted Fri, 27 April 2007 at 2:56 PM
Hello, all.
Just installed DS 1.5 after running 1.4.16 successfully for some time. It appears that, when I load the AH light source for IBL lighting, although it is successfully added to my Scene tab, nothing appears for it under the Parameters tab.
Any suggestions are welcome... thanks...
-Whirlwind
prixat posted Sat, 28 April 2007 at 1:53 AM
I'm not having any problems with the shaders in the new version. Are the AH hair and AH skin shaders working OK, it may be an installation issue?
regards
prixat
RHaseltine posted Sat, 28 April 2007 at 8:51 AM
Shaders do require files that get installed to folders in the root folder of the D|S installation - eg StudioShaders - so if you deleted that folder, or installed to a different folder and just linked or moved your Content folder, those may well be missing which would potentially cause such problems (there's a definition file, as I recall, which tells D|S which parameter controls are needed).
