Subject: What am I doing wrong?
Nosiferret opened this issue on Apr 29, 2007 · 4 posts
Nosiferret posted Sun, 29 April 2007 at 11:21 PM
Hi. I am using Poser6 and DM's Nanette figure. I can't figure out why my eyebrows and eyelashes are not coming out as clear and crisp as DM's on their merchant page. I've added a render of what I keep coming up with.
Miss Nancy posted Sun, 29 April 2007 at 11:27 PM
bad AO setting?
Victoria_Lee posted Sun, 29 April 2007 at 11:36 PM
If this is using the Firefly render engine, set Texture Filtering to On
Hugz from Phoenix, USA
Victoria
Remember, sometimes the dragon wins. Correction: MOST times.
bagginsbill posted Mon, 30 April 2007 at 12:08 PM
No - do not set texture filtering on.
You must change render settings.
Set Min Shading Rate to .2, and Pixel Samples to 5 for highest resolution rendering.
Also, make sure that your Max texture size is not reducing the image resolution. If you have it at 256 or something, then even if you have a 4K by 4K texture image, you effectively only have a 256 by 256 image - which is blurry. You want 1K to 4K on that setting for high-res closeup work. Make sure after you change it that you "Reload textures" if you have "Keep textures loaded" turned on. Otherwise, the texture last loaded (and shrunk down) will still be there.
