Forum: Carrara
Subject: Textures missing with HDRI when importing Poser characters
morph6877 opened this issue on Apr 30, 2007 ยท 3 posts
morph6877 posted Mon, 30 April 2007 at 4:24 PM
When I import a model from Poser and render using HDRI the hair texture is missing. I've attached a render to illustrate. Any ideas as to why this is happening?
MarkBremmer posted Mon, 30 April 2007 at 4:27 PM
Hi Morph, If the texture shows up when you are not using Global illumination, than the fix is to enable "light through transparency" in both the regular render settins AND the Global illumination settings. If the texture is simply gone upon import, than there is something else going on. Mark
morph6877 posted Mon, 30 April 2007 at 5:00 PM
Thank you that worked.
