Forum: Carrara
Subject: Glass shader causes blotches in GI Render - anyone know why?
craftycurate opened this issue on Apr 30, 2007 · 22 posts
craftycurate posted Mon, 30 April 2007 at 7:31 PM
Am experimenting with some renders based on some of the "Indoor" Carrara 5.1 presets.
However, when I put glass in the two windows on the left and right of the scene, I get mysterious blotches appearing. Anyone know why?
Render uses Sky dome, and a distant light, with Indirect Light, "Excellent" light quality, 100K photons, 35% photon map accuracy.
I am using the standard "Clear" glass shader with no bump map. Images below are "with" and "without" glass.
Any ideas how to fix this? I have already banged up the quality settings quite a lot but can't get rid of blotches.
Thanks
Richard
MarkBremmer posted Mon, 30 April 2007 at 8:33 PM
Hi Richard, Try enabling "Improved Edges" in the GI renderer and also enable "Full Raytracing" at the top of the regular render settings. Interpolation let's Carrara 'guess' where the photons go instead of actually figuring it out. So, interpolation is giving Carrara permission to make mistakes for the sake of improved render times. Full Raytracing will extend the render times but yields better results because it forces Carrara to do complete calculations. You can also try Interpolation in the 80-100 percent range. That will work somtimes but it depends on the scene. Mark
jt411 posted Mon, 30 April 2007 at 11:37 PM
Alright I'm getting confused Mark.
Are you saying that leaving Interpolation unchecked in the GI renderer will produce better results, but longer render times?
Miss Nancy posted Mon, 30 April 2007 at 11:47 PM
yeah, he's saying "no interpolation". that's been a common thread in this forum. I continue to be amazed, after 10 years with ray dream and carrara, with what the latter can do for such a small selling price.
craftycurate posted Tue, 01 May 2007 at 2:59 AM
OK thanks ... here's the same scene (with glass hidden) with everything at max (tho I just realised that "Full Raytracing" was not selected).
The thing I notice (which might be fixed by removing interpolation and selecting Full Raytracing) is the errors in ambient occlusion between the back and side walls and the ceiling.
Any thoughts about errors in ambient occlusion?
Thanks
Richard
Hoofdcommissaris posted Tue, 01 May 2007 at 3:23 AM
I think that would be fixed with interpolation turned off too. If that leaves something to be wished, I guess the photon accuracy needs to be higher. A lower value probably leads to some type of interpolation too. Good luck!
ShawnDriscoll posted Tue, 01 May 2007 at 9:11 PM
These are things I learned about Carrara Pro 5.1 through trial and error:
GLOBAL ILLUMINATION
Avoid using Improved Edges.
Use Full Raytracing only if blackness appears in scenes (missing polygons).
Always turn off Interpolation for final renders (a huge render hit will be
taken, though).
Turning on Caustics will allow more Indirect Lighting to work through glass.
But the render takes an extreme hit and the resulting caustics might look
over-kill for a scene.
Turn up a scene's ambient lighting to around 40% before using Ambient Occlusion.
Otherwise, everything will be dark.
Miss Nancy posted Tue, 01 May 2007 at 10:23 PM
what I found with caustics was that filter=30% is about right. filter=100% causes severe photon overexposure, whilst filter=0% causes blotchy photon underexposure.
craftycurate posted Wed, 02 May 2007 at 11:37 AM
Useful tips, thanks.
I wonder if the problem with ceiling ambient occlusion here is the oversaturation due to light reflected from the floor?
TerraMatrix posted Fri, 11 May 2007 at 10:07 PM
I've got a similar problem. I hope I'm not hijacking this thread, but I didn't want to start another with such a similar topic. I was rendering hair last night, and got all these dark artifacts, mostly concentrated at the tips.
TerraMatrix posted Fri, 11 May 2007 at 10:13 PM
These are the render settings. Does anybody have an idea what specific factors could be causing it? It always takes so long to render with this hair, I'd rather not have to do very many test.
MarkBremmer posted Sat, 12 May 2007 at 12:08 AM
Hi TM, You need to increase your Ray Depth. Mark
Sydney_Andrews posted Wed, 16 May 2007 at 10:23 PM
I used that hair as well. I would uncheck Interpolation and get ready for a long render. E
craftycurate posted Thu, 17 May 2007 at 5:10 AM
Through experimentation, I've discovered some ways to reduce (though not completely remove yet) the ambient occlusion blotches
  1. Reduce overall light level
  2. Darken textures a little, and undersaturate colours a little
  3. Bang all settings as high as your patience and CPU will allow!
  4. No Interpolation, Full Raytracing
(Am not sure which of these changes has the most effect though)
Overall render will come out darker than desired, ubt this can be reversed by loading into Photoshop (or equivalent), duplicating the image onto a second layer which is given a "Screen" blend mode, and this restores the lightness, but a little detail might be lost.
Miss Nancy posted Thu, 17 May 2007 at 5:11 PM
I like that render of the girl. it's probly relevant to point out when they say "no interpolation", it means "unchecked" (as mentioned above) rather than 0%. I dunno if carrara has a skin node/channel/shadert as poser does, to allow sub-surface scattering.
sparrownightmare posted Thu, 24 May 2007 at 9:18 AM
Quote - These are the render settings. Does anybody have an idea what specific factors could be causing it? It always takes so long to render with this hair, I'd rather not have to do very many test.
Increase ray depth to 8 minimum, and rduce filter sharpness to 65=70%.  This gives the room a slightly warmer more realsitic look.  Also make sure you dont have something in your scene settings as a background.  An image map in there or some kind of procedural could cause problems like those spots.
If you are using realistic sky or sky, just turn it off since it will not really show in the render with the camera angle you are using.
craftycurate posted Mon, 28 May 2007 at 6:45 AM
After exhausting all the possibilities I can think of, and rendering at the highest quality available, and after taking note of some hints from 3D professionals (out of Jeremy Birn's "Digital Lighting and Rendering", I've discovered another more lateral approach ...
Export the Carrara scene to a 3DS file, and import into Vue 6 Infinite to take advantage of the higher quality GI and radiosity lighting there!
That's given me some ideas about how I might improve the Carrara renders.
ShawnDriscoll posted Mon, 28 May 2007 at 10:16 PM
I have removed ashes in the past from similar scenes by not including the Skylight in my GI renders.  I instead placed colored distant lights in areas to simulate the skylight.  You can probably leave Interpolation on at 20% so the render will finish quickly.
craftycurate posted Mon, 28 May 2007 at 10:22 PM
thanks for useful tips
jubjub64 posted Tue, 29 May 2007 at 11:11 AM
I don' t know if this is the case with Carrara but in another 3D program I have (Shade) if two objects are overlaping it causes rendering errors when using global illumination.  I noticed that the walls and ceiling in this Carrara file are overlaping separate peices.  Maybe if you used boolean operations to weld them all together it would take away the blotches.
craftycurate posted Tue, 29 May 2007 at 11:35 AM
Thanks for this - will give it a go. yes, a lot of the rendering errors occur at the corners between objects.
craftycurate posted Tue, 29 May 2007 at 6:18 PM
Here's an attempt to recreate the scene in Vue 6 infinite for comparison - although the overall quality of GI is much better in the corners, there is still some blotching noticeable in the left hand sofa.
