iloco opened this issue on May 02, 2007 · 10 posts
iloco posted Wed, 02 May 2007 at 7:55 PM
ïÏøçö
iloco posted Wed, 02 May 2007 at 8:41 PM
mrsparky found a mouse trap for me so I am not needing one unless someone can find one textured as the one in the pic. :)
ïÏøçö
Harrgunn posted Fri, 25 May 2007 at 9:17 PM
Attached Link: Mouse trap in the works
I see you already found one, but this got me to thinking. Thought I would try to work on a posable trap for use in poser that could be animated. Far from done, but think the mechanix of it are getting worked out. Any ideas or suggestions... let me know.This will take a moment to load, then it speeds up.
iloco posted Sat, 26 May 2007 at 5:55 AM
I found one but not exactly what was looking for. Yours is looking great. Will it have a good texture like the one in the pic I attached, :)
ïÏøçö
Harrgunn posted Sat, 26 May 2007 at 5:38 PM
You did not mention if had to be a posable/movable model, but I do like building things that move. I still have to work out the latch and release mechanisms. Would think adding texture maps will not be hard. Unfornatually I am working this weekend so can only dabble here in the evenings. Will update here as it happens. If you can turn up a graphic of just the logo, straight on, that would help. I see the spring assembly is a bit different, is that a problem? Can re-build if needed.
Catch ya later,
(yea, thats a pun)
iloco posted Sat, 26 May 2007 at 5:41 PM
What you are doing looks great to me. I looked for a better pic of the texture but didnt find one I thought may be ok. :)
ïÏøçö
Harrgunn posted Tue, 29 May 2007 at 8:18 AM
Click the pic for a bit clearer view.
Harrgunn posted Tue, 29 May 2007 at 10:03 AM
Attached Link: See the animatiion here.
Have the mechanical end working. guess now I should get some cheese and peanut butter. Click above on the link to veiw the latest animation. Still some materials work to do.Harrgunn posted Sat, 02 June 2007 at 8:04 PM
Think is as done as I'll get it. Have it posted up here....
oddboots posted Mon, 11 June 2007 at 5:48 AM
looks great! I'd love to have the model, is it possible to get hold of it at the moment?
