Imager opened this issue on May 06, 2007 · 8 posts
Imager posted Sun, 06 May 2007 at 4:33 PM
I'm going to buy a new pc. The new ones all come loaded with Vista. I've heard Photoshop and Painter have problems working with Vista. Is that true? Thanks. -Drew
aprilgem posted Sun, 06 May 2007 at 5:01 PM
I don't plan on buying a new pc, but I'd love to know the answer to this one, too.
NomiGraphics posted Sun, 06 May 2007 at 8:44 PM
Photoshop CS2 and Vista didn't work together on my machine.
CS3 works great with Vista.
- Noel
rigul64 posted Mon, 07 May 2007 at 4:34 PM
I'm running CS2 with Vista with no problems.
suppersready posted Tue, 08 May 2007 at 12:34 PM
Hello, I've installed Vista 64 bit Business edition. If you have Creative suite CS2 there is a way to install it like I did. When the program ask you where to install, create on the desktop a folder called ADOBE and install everything in there. Guaranteed it will work. The only minor problem is that you have a folder called Adobe on your desktop, wich I consider a good idea if you want to add fliters,shapes,styles and so on.
viper posted Mon, 14 May 2007 at 8:29 PM
I just purchased my new laptop and after installing CS2 I cant load it as when I try to get thru registration part it tells me I dont have admin rights to continue but I am the admin on the PC.
NomiGraphics posted Mon, 14 May 2007 at 9:09 PM
You probably need to run the install as an admin.
Right click on the install program, and run it as an admin, see if that fixes the issue.
- Noel
one5910 posted Thu, 17 May 2007 at 1:24 PM
Attached Link: one5910
hello I am just a child when we speak about Computers i did try today to work with photoshop 7 and vista an hp tv 3020 it seems that i could work a little on this contest the new one. so i did send a exemple for the web flatten. regarding problems i did have some with som effects. rendering can give a little problem and sometimes some of the effects are not usable on some layers. but i am not an expert. i have all the work and the layers for the contest original but i couldn'nt send them so i just sendt those small thumb and flatten. but you know that when they put a poduct on the market it is not finished they hope feed back. regards one5910
