Subject: V4 question
Kaylic opened this issue on May 11, 2007 · 6 posts
Kaylic posted Fri, 11 May 2007 at 5:16 AM
Since there is no "stretch neck" morph on V4, I was wondering if there is some way that you can unlock the y-scaling on her neck to manually lengthen it?
pjz99 posted Fri, 11 May 2007 at 5:27 AM
Hmm, I am fairly sure there is a neck longer/shorter dial in MorphForms branch for the neck.  Although to answer your question, there is a pose file that circulates around that DavidGB at the DAZ forums wrote and made available, I will search it up for you.  I have found that you can adjust scale to a small degree for bodyparts, but if you take it very far it can often cause the limbs to destort very badly.  You'd be safer checking the Neck again.
This dial I'm thinking of might have been something added with V4.1's update, and I'm not completely sure it's there at all.
My Freebies
pjz99 posted Fri, 11 May 2007 at 5:31 AM
http://www.david.eaton.ukgateway.net/RevealScaleDials.zip
My Freebies
Kaylic posted Fri, 11 May 2007 at 5:34 AM
Yeah, I didn't plan on over doing it much.. just wanted a little more legnth. I got the v4.1 update and was hoping it would have something like that but it doesn't. If I could get a link to that file it would be great.
Kaylic posted Fri, 11 May 2007 at 5:35 AM
Got it up as i was replying. thanks :)
Ghostofmacbeth posted Fri, 11 May 2007 at 9:36 AM
There isn't a morph for it, unfortunately. I hate her short little neck.
