mr_Holger opened this issue on May 12, 2007 ยท 3 posts
mr_Holger posted Sat, 12 May 2007 at 2:20 PM
hello,
as an modern alchemist, I tried create a new kind of amalgam: merging of communism and
the spirit of the "born to be wild" thing. I had the hope, this could be the answer of all the globalisation problems...
but seriously, I had a project in mind to combine W.I. Lenin with the biker's-cap of Turbonegro (don't now, wheather someone here knows that scandinavian punk-rock guys or not).
but the result is not perfect. I have only two pictures, but they do not really fit together.
just look here:
this is "my" lenin:
and this is the Turbonegro's cap:
but merged together, it is this:
could it be a solution to take a 3D-cap (perfect: the one at Chris Townley's Freestuff ), turn and scale it a little bit and save as 2D-file, and then merge the pictures together?
and if so: could anybody here help me to do this and match it to lenin?
my postwork-knowledge is very little.
thanky you very much!
Holger
Miss Nancy posted Sat, 12 May 2007 at 3:08 PM
pose a figure's head with shape similar to lenin (e.g. apollo max.) against a background with that image. pose it to match the background. add cap. render as cartoon-with-lines, use olivier's toon shader, use poser 7 toon render, or use poster edges filter in photoshop.
mr_Holger posted Sat, 12 May 2007 at 3:25 PM
thank you.
I will try this.
