Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 02 5:01 am)
That depends on how you are doing the morph itself. At a value of 1, it represents the morph as it was imported. So if there is an increase in size, it means that while morphing the part you accidentally enlarged it.
I sometimes (in Silo) load the original part, make the morphed part transparent and check for potential problem spots.
However, the problem spots depend on what you were morphing, and how you morphed it. There is no easy answer.
Unless of course, you are scaling the obj files, either in Silo or in Poser. If you must do this, use an easy value (eg. 100 instead of 304.8) on scaling up or down, scaling by fractions can generate scaling errors because of different implementations of floating point calculations.
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
The morph I made.
Does not enlarge / scale V4 Dev Example and morphs correctly**.**
Does not enlarge / scale V4 Dev Foundation and morphs correctly.
Enlarges / scales Victoria 4.1 and morphs wrong,witch is the one mesh I need to work correctly.
This is confusing and I have no idea why the Victoria 4.1 morphs are not working correctly.
Any ideas ?
RorrKonn
http://www.Atomic-3D.com
The
Artist that will fight for decades to conquer their media.
Sorry, I cannot help you with that. Did you use Victoria 4.1 as base when you exported the mesh before morphing?
Since I neither own Vic4 nor plan to buy her in the next days, I cannot tell the differences.
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
They say do not export out of Poser, alt to get the meshes from PoserRuntimeGeometries folders meshes are zeroed.
PoserRuntimeGeometriesDAZPeopleblMilWom_v4b.obj
I'm using C4D getting use to using morphing tools.
I scale V4 2000 to 4000 Poser has the smallest work space.
I need to write a tutorial on how to do all this so I don't forget the 100 little thing you half to do absolutely correctly.
blMilWom_v4b.obj is all of V4
V4DevSuit.obj is just her body no hands,feets, head
Since I was just making a body morph I used V4DevSuit.obj bad bad idea.
V4DevSuit.obj is a little bit biger then blMilWom_v4b.obj
So the moral of the story is do not use V4DevSuit.obj to make morphs.
Only make morphs with blMilWom_v4b.obj.
Anyways we now can finally make V4 Morphs.
Now to make the morphs available to the public.
I know one way is to make INJ's.I currently do not have a INJ app.
Is there a free way to make INJ's ?
Can I save the mesh in poses with morphs as a .pz2 and release them that way ?
I know there are several deferent app's people has suggested I alt to buy but there's no demos and don't know witch ones I alt to buy or really need.
RorrKonn
The
If for Poser6 and Poser7, use external binary morph targets and check nerd3d tutorial on getting morph targets this way. No need to worry about copying restricted content, no need to use the objaction mover utility, etc etc. It is reaaaally very simple this way.
Visit my blog! :D
Get Poser's little helper to make INJ poses. http://home.online.no/~kjellil/Injection.htm FREEEEEE
It works pretty slick :)
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
May be I did not ask this correctly.
How do we get a morph with out enlarging the mesh ?
RorrKonn
