dennisharoldsen opened this issue on May 15, 2007 · 7 posts
dennisharoldsen posted Tue, 15 May 2007 at 2:34 PM
thanks for the previous crucial help from nruddock and PhilC.
it would be nice to have a script to reverse the pose of a character.
i got the idea from the folowing script.
this is a script i downloaded.
sometimes it works but the result is not always what i expect.
i can send images to show this.
import poser
scene = poser.Scene()
try:
TheFigure = scene.CurrentFigure()
except:
exit
scene.SetFrame(0)
TheFigure.SwapTop()
TheFigure.SwapBottom()
MidlineList = ["BODY","Neck","Upper Neck","Head","Chest","Abdomen","Hip","Left Eye","Right Eye"]
for Name in MidlineList:
try:
OneActor = TheFigure.Actor(Name)
except:
pass
try:
TwistParm = OneActor.ParameterByCode(poser.kParmCodeYROT)
TwistParm.SetValue(-TwistParm.Value())
except:
pass
try:
SideParm = OneActor.ParameterByCode(poser.kParmCodeZROT)
SideParm.SetValue(-SideParm.Value())
except:
pass
PhilC posted Tue, 15 May 2007 at 2:51 PM
Rotoscoper has that and a number of other posing options.
svdl posted Tue, 15 May 2007 at 3:07 PM
I've rewritten the script to swap all figures, independent of Poser language and body part names. See attached file. Save as SwapFigure.py.
dennisharoldsen posted Tue, 15 May 2007 at 4:43 PM
PhilC
thank you.
i have done lots of research to understand poserpython.
you are one of the few who does.
Rotoscoper sounds very capable and i going to check it out.
i am looking at learning more about poserpython.
it is dramatically under-doucumented.
is the python code in Rotoscoper visible?
maybe we can talk.
dennisharoldsen posted Tue, 15 May 2007 at 4:50 PM
thank you.
your code is quicker and more reliable.
however, the result is still varied.
i am sending my test results as a jpg.
it shows an initial pose that is changed and changed again.
i am trying to understand poserpython but it is a challenge.
you know that better than i do.
jonnybode posted Fri, 18 May 2007 at 12:51 PM
Hi Dennis!
Excuse me if this is a silly question, when I swap a pose i go to "Figure/Symmetry/Swap right and left", I guess you are after something more?
Im just curoius what the result of your script shall be?
Regards / Jonny
jonnybode posted Sat, 30 June 2007 at 3:48 AM
