Forum: Vue
Subject: Render times with water
MarkHirst opened this issue on May 16, 2007 · 24 posts
MarkHirst posted Wed, 16 May 2007 at 1:16 PM
We all know what water can do to render times ! My dilemma is that to try and get render times that don't go off into infinity, I seem to be making more and compromises to the overal quality of the picture. Can any body suggest tips that can speed up the render of the water without losing out overal. Using Vue 5 Pro Studio BTW.
www.CambrianMoons.com
bruno021 posted Wed, 16 May 2007 at 2:02 PM
No tips, really, water takes a long time to render. Maybe reduce bump, but do keep some, unless you want to render a very still lake, you can also reduce the reflective angle to get less reflections. Check that you are not using a material that has blurry reflections and/or transparency.
CobraEye posted Wed, 16 May 2007 at 2:24 PM
Lower trace reflections and transparency to 1.
bruno021 posted Wed, 16 May 2007 at 3:14 PM
Won't work, CobraEye, apparently this setting doesn't apply to water. You can set it to 1 or 12, it will be just the same. This parameter only works when the reflectivity channel is active, not this "fresnel like" reflectivity that is activated in the transparency channel. As for transparency, it is always computed the same, I don't know why this parameter is active for transparency.
And it's Infinite only, btw.
haegerst posted Wed, 16 May 2007 at 4:23 PM
Basically theres just a few things that really eat up loads of rendering time:
theres many more little things you can tweak. If vue keeps your HDD busy during render, then physical memory is the bottle neck, try to refrain from rendering such scenes as they take like 10 times longer when you lack the ram.
Vue content creator
www.renderarmy.com
CobraEye posted Wed, 16 May 2007 at 8:57 PM
You are right. It doesn't help render time, but does change the color of the water.
bruno021 posted Thu, 17 May 2007 at 4:14 AM
Really, CobraEye?  I tried to up the reflection passes once, but couldn't see any change in the water quality. Will try again. Thanks.
CobraEye posted Thu, 17 May 2007 at 8:22 AM
I noticed the change when the setting is switched from 1 to 5.  It is quite a surprise that it does not change render time.  Thanks for the excellent explanation.
bruno021 posted Thu, 17 May 2007 at 8:41 AM
Very visible indeed. My user settings always use 5 levels of tracing. Have you seen any improvement if you go over 5?
MarkHirst posted Thu, 17 May 2007 at 1:05 PM
Some useful suggestions, many thanks. I'm wondering perhaps I should render the scene with water at a lower quality setting, and then render the scene again without the water at a higher quality setting and use a mask to combine the two. My render is still running and the skin tones on the figure are noticeably poorer with the lowered quality settings. :-(
CobraEye posted Thu, 17 May 2007 at 2:40 PM
I think it is a good idea.  I've often thought about doing it myself, but I usually just go for the long render.
Bruno, I see no improvement over 5.
bruno021 posted Thu, 17 May 2007 at 4:06 PM
Ok, CobraEye, this is why I neversaw any improvements with this feature, because I always start at 5. Good to know there is no need going over 5.
kore21 posted Fri, 25 May 2007 at 3:13 PM
godrays & water are the kiss of death for render time. i've given up on seascapes & godrays.
stormchaser posted Sat, 26 May 2007 at 6:52 AM
"godrays & water are the kiss of death for render time. i've given up on seascapes & godrays."
kore21 - I found out the hard way on this as well!
chippwalters posted Sat, 26 May 2007 at 10:21 PM
You might consider turning OFF transparency for the water...if you don't need it. It will substantially decrease the render time.
kore21 posted Sat, 26 May 2007 at 10:27 PM
what does turning off the transparency do to the look of the water? also, would objects/terrain under the surface no longer be seen?
bruno021 posted Sat, 26 May 2007 at 11:19 PM
Turning off transparency for water would make water look like a metal material. Objects underwater would no longer be seen.It's a good trick for distant water.
kore21 posted Sun, 27 May 2007 at 12:40 AM
hmm, could be interesting for some things. i'll take a look sometime.
kore21 posted Sun, 27 May 2007 at 5:23 PM
i just have the latest patch on, seems they fixed the memory leak & my rendering is a lot faster. as a matter of fact it's about 1/3 of what it was, so far experimenting w/ "optimize last render pass." godrays & water may be saved from oblivion....
bruno021 posted Mon, 28 May 2007 at 1:59 PM
Optimize last render pass  speeds up the render times, but is less acurate, since it evaluates the lat render pass from the previous passes, without raytracing. It can become really ugly with advanced lighting models. You can't network render with this option on, btw.
kore21 posted Mon, 28 May 2007 at 10:01 PM
i've been experimenting with "optimize last render pass" since many other ppl have recommended it. mostly with relatively uncomplicated things. a few of them have come out with smudgier areas, or a little flat. render time was 1-3 hours using a spectral atmosphere, for what was previously 7 (not counting godrays). so i will probably be using full quality most of the time. which means where do i put the quality boosts, these increase the render time. for example, i'm often running 2+ on the sky, fog & haze panel. lowering this unfortunately changes the color/quality of the sky too much for my liking. seems it's easiest to decide first what you want the quality to be, THEN design the atmosphere for best results. some ppl have said you must have 4+ for rendering godrays, that's the only one i've ever tried. most of the time i've aborted the render, since it wasn't practical & kept my computer tied up too long. if they've fixed the memory leak it's now worth a try to render godrays.
notice they also fixed the anti-aliasing, where it got stuck on "soft" & water turned to metallic sludge. crisp seems to work now.
bruno021 posted Tue, 29 May 2007 at 2:19 AM
The atmo quality boost should only be used if you see grain in the clouds. Because that's all this parameter does: increase the cloud samples to avoid grain. It doesn't change the sky colour. Of course with godrays, most of the time you need a +4, because your clouds have to be very dense and thick, with a lot of shadows to compute, and the grain comes where the shadows are.
kore21 posted Tue, 29 May 2007 at 3:47 AM
thanks. i like playing with the hazes, i find if i turn it down too much it looks a little flat or something.
one thing i noticed with godrays, the graininess seems to be extended somewhat beyond the cloud itself, basically increasing graininess in the sky color. thought this was a bit of a nuisance to get rid of. found lowering the cloud opacity helps here somewhat.
bruno021 posted Tue, 29 May 2007 at 4:31 AM
Lowering the cloud opacity will reduce grain,but maybe the godrays will be less visible too. It's a trial and error thing. Sahme it takes so long to see the results.
