Subject: Any way to remove Aiko 3's Morphs?
onimusha opened this issue on May 21, 2007 · 5 posts
onimusha posted Mon, 21 May 2007 at 8:59 PM
When I make a character, I usually use the "spawn morph target" command on each body part to minimize the size of the figure.  Then I remove the morphs so they won't suck up huge amounts of space on my HD.  Is there a way to remove Aiko 3's morphs?  I don't think it comes with a Poser file for that.
Thanks...
svdl posted Tue, 22 May 2007 at 12:54 AM
My RemoveMorphs script will do the job: www.svdlinden.nl/webposerstuff/downloads/removemorphs.zip
It'll remove the morph deltas of all morphs that are set to zero, and it'll hide the dials.
The included .exc files make sure that JCM morphs and expression morphs are excluded from the removal. You don't have to specify what .exc file to use, the script figures that out all by itself.
Hope this helps,.
Steven.
My gallery   My freestuff
onimusha posted Tue, 22 May 2007 at 6:03 AM
Thanks... this'll be helpful...
ezuk posted Tue, 22 May 2007 at 2:16 PM
Thanks for posting this script, svdl; your generosity is greatly appreciated.  The script worked like a charm for me, and I was able to extend it easily to Hiro by renaming a copy of Aiko's .exc file.
momodot posted Tue, 22 May 2007 at 4:45 PM
I really struggle with this. This week I have been using PhilC's Poser Tool Box which can create a full list of morphs for a figure then delete all the morphs on the list.  I go through the list and remove my character, the expression morphs and the JCM morphs before running the delete script. svdl SpawnCharacter is great for V3 but I am using this Poser Tool Box method as my latest way of dealing with Ruduced Resolution and third Party figures as well as M2 and V2. Hmm. Not perfect but it seems to be working.
