Marque opened this issue on May 23, 2007 · 16 posts
Marque posted Wed, 23 May 2007 at 7:13 PM
It seems to be clipped on either side, never had this happen before. Is it because I set it to run like Maya? And if so how do I get it back?
Thanks,
Marque
dsr207 posted Wed, 23 May 2007 at 8:50 PM
Right click on view display options (first icon in your main camera view window) and go to frame guides and change it .
Marque posted Wed, 23 May 2007 at 11:55 PM
Nothing I change it to changes it. What am I doing wrong here?
Marque posted Thu, 24 May 2007 at 12:00 AM
No matter what I do I still have the strips on either side, frustrating.
Marque posted Thu, 24 May 2007 at 12:19 AM
Instead of right clicking on the icon I went to display and changed it. Thank you for pointing me in the right direction!
Marque
Marque posted Thu, 24 May 2007 at 12:22 AM
Grr worked until I rendered it then it went back to the strips on either side.
bruno021 posted Thu, 24 May 2007 at 3:27 AM
Sorry but what strips? Could you post a screengrab?
Marque posted Thu, 24 May 2007 at 10:08 AM
The main area used to cover the viewing area. Now I have these strips of nothing on either side and it's driving me crazy as my pic extends on either side but those areas don't render. I'm thinking I must have chosen something in the options to do this. Is there any way other than re-installing the program to reset it?
Thanks,
Marque
Marque posted Thu, 24 May 2007 at 10:14 AM
spedler posted Thu, 24 May 2007 at 10:38 AM
This is due to the aspect ratio you chose (maybe without meaning to) for the image. It's normally set to standard PC 4:3 which fits, as the name implies, on the screen (assuming you don't have some odd monitor size). If I choose standard PC vertical 3:4 I get the same bars as you. Vue is showing you the non-renderable areas due to the chosen aspect ratio.
Just set it back to standard in the render settings and it'll be OK.
Steve
bruno021 posted Thu, 24 May 2007 at 1:31 PM
Actually it's because the size of your screen doesn't have a 4/3 ratio. The strips are here to show you only what will be rendered at the size you chose in the render options (or a 4/3 ratio by default)
spedler posted Thu, 24 May 2007 at 1:43 PM
It would be interesting to know if Marque has just changed his display, because if not (and if it all looked okay beforehand on the same monitor) I stil think that the image aspect ratio must have changed. According to my quick calcs the screenshot is 1360 x 768 - which is a perfectly respectable monitor size, but well off the 4:3 ratio, so yes, it could be the display size causing this.
Have to say though that my monitor is not 4:3 (it's 1280 x 1024, which is 5:4) and I don't get those strips with an image of 4:3 aspect ratio.
Steve
bruno021 posted Thu, 24 May 2007 at 2:41 PM
Spedler, my screen is like yours, and I do get the strips, only very tiny, and at top & bottom.
spedler posted Thu, 24 May 2007 at 3:09 PM
Perhaps they're so small I haven't noticed them!
Steve
bruno021 posted Thu, 24 May 2007 at 3:51 PM
I hadn't noticed them either before your post, actually!
chippwalters posted Thu, 24 May 2007 at 9:51 PM
