wurk2hard opened this issue on May 25, 2007 · 8 posts
wurk2hard posted Fri, 25 May 2007 at 4:53 AM
Ok, I know I am a bit of a beginner here, but I cannot find the poser 4 skeleton textures anywhere. Could one of you good people direct me to the appropriate place.
Thank you in advance.
~Wurk
Miss Nancy posted Fri, 25 May 2007 at 12:25 PM
I only recall that the daz skeletons had textures. as ya know, the P4 skeletons (additional figures) didn't come with textures.
mertext posted Fri, 25 May 2007 at 12:28 PM
the original P4 skeletons have no textures and their UV mapping is pretty sad as well (ie dificult to work with to get a good looking skeleton) You can use UV mapper to remap them and create a new base figure. if thats too dificult, then just pose the way you want, export as an obj. and remap using uvmapper for that pose. I had to do that on more than one occasion when first starting out.
aka MCDLabs
also known as Daniel Merrill a grumpy old disabled Jarhead.
checkout my freebies at
https://www.sharecg.com/pf/full_uploads.php?pf_user_name=mcdlabs
wurk2hard posted Fri, 25 May 2007 at 12:38 PM
Ack, that is sad. Thanks both of you for your replies.
Mertext, is uvmapper another program? Like I said, pretty new to the whole editing thing, so forgive me if my questions sound a bit noobish.. but, they are, hehe.
~Wurk
Maxfield posted Fri, 25 May 2007 at 7:44 PM
UV mapping means you take a 3D model to pieces and lay them out flat like a tailor's pattern. You then save the model and an image of the flat pieces. You can use this image as the basis for painting a texture (in Photoshop, for example).
UVmapper is a popular program for doing this. A limited, freeware version is available.
Be aware that the early Poser models were a bit crude, and UV mapper can mess up the skeleton model - it did for me! But you can re-map the skeleton with a bit of work.
wurk2hard posted Fri, 25 May 2007 at 9:29 PM
Excellent, a trial version is just what I need to see if this is something that interests me. Although, it probably will. Thanks again.
Dajadues posted Sat, 26 May 2007 at 3:15 AM
There's UVMapper Classic, it's free.
kawecki posted Sat, 26 May 2007 at 3:56 AM
You can use a metal rust texture for the P4 skeleton, depending on the texture used the skeleton can look very nice!
Stupidity also evolves!
