Forum: Bryce
Subject: all objects can be export ?
frackzdraf opened this issue on May 28, 2007 · 16 posts
frackzdraf posted Mon, 28 May 2007 at 5:01 AM
hello,
 i'm thinking to buy bryce.
but can we export all meshes,all kind of objects in OBJ ?
thank you for your precious help
TheBryster posted Mon, 28 May 2007 at 6:13 AM Forum Moderator
We've always been able to export terrain meshes, but with Bryce 6.1 you can now export a boolean conversion, that is if you take a positive and a negative and boolean them, you will get a 'convert' icon [c] on the icon column. You can then export this as an obj, dxf, etc.......
Hope this helps.
frackzdraf posted Mon, 28 May 2007 at 9:26 AM
thank you for reply
so, in what you say, that thus applies to all the objects, not only to the imported ones ?
I want to say, also the native objects 'manufactured' in bryce with primitives ?
 ( my english isn't very good , i always need to repeat :blushing: )
thank you
dvlenk6 posted Mon, 28 May 2007 at 9:38 AM
Everything can be exported except metaball constructs. Trees are metaball constructs.
Friends don't let friends use booleans.
frackzdraf posted Mon, 28 May 2007 at 2:15 PM
ok thank for your replies thebryster and devlenk6
TheBryster posted Tue, 29 May 2007 at 6:36 AM Forum Moderator
You're welcome!
jenay posted Tue, 29 May 2007 at 9:27 AM
I read about the ability of boolean export -
does this work correctly ?
is there anybody who tested this successfully ?
can these objects re-imported into other 3d applications (incl. Poser) ?
are there any limitations in depth of boolean combinations ??
that would be interesting
Death_at_Midnight posted Tue, 29 May 2007 at 11:16 AM
Boolean export works well. I often export an object to import into other apps, specifically the Ivy Generator. The most complicated objects I've boolean exported has been my Japanese lanterns, arches, sundials, pillars, ....
TheBryster posted Tue, 29 May 2007 at 1:56 PM Forum Moderator
I can assure you that I have tested this particular bit of Bryce-candy extensively. It works just fine!
My only gripe is that when you hit the [c] icon, the group keeps its original bounding box size. However, that is corrected when you re-import the item into Bryce.
dvlenk6 posted Tue, 29 May 2007 at 2:32 PM
Death_at_Midnight AND TheBryster are exporting from Bryce? :blink:
Some sort of schism in the Sacred College of Cardinals?
Excommunicated heretics around the world want to know.
Death_at_Midnight posted Tue, 29 May 2007 at 6:44 PM
LOL!  :-)
When the Ivy Generator is involved, I think it is okay to export to it.... afterall, one must import back into Bryce that cool ivy. ;-)
TheBryster posted Tue, 29 May 2007 at 7:33 PM Forum Moderator
As I said earlier, using the [c] icon still leaves the original bounding boxes and that can cause problems. Better to export and then import BACK INTO Bryce which means you get a 'clean' object. This is wholly in keeping with the sanctity of the Blessed App.  ;-)
dvlenk6 posted Wed, 30 May 2007 at 11:21 AM
Quote - As I said earlier, using the [c] icon still leaves the original bounding boxes and that can cause problems. Better to export and then import BACK INTO Bryce which means you get a 'clean' object. This is wholly in keeping with the sanctity of the Blessed App.  ;-)
Sounds like a cover-up to me.
I think TheBryster has secretly been using heretical apps. but doesn't want to be condemned by his fellow cardinals as a heretic. :lol:
TheBryster posted Wed, 30 May 2007 at 6:51 PM Forum Moderator
*Sounds like a cover-up to me.
*That's slander!
pakled posted Fri, 01 June 2007 at 7:32 PM
why would you export a blessed boolean construction out of Bryce in the 1st place, except...ahem...to use it in another program?..;) Inquiring minds want to know...I'll make room on the comfy chair...prepare the soft cushions...;)
Death_at_Midnight posted Fri, 01 June 2007 at 8:08 PM
Hehe, I do it from time to time now. That Japanese lantern (http://www.renderosity.com/mod/gallery/index.php?image_id=1374731&member) was a Bryce 5 project, converted in Bryce 6. I've been wanting to make this into a freebie for a while, so I use it to make sure it behaves right before making it available.
But you're right.. it's handy to have it exportable for other apps to alter it. The only two other apps I use to enhance Bryce is in terms of exporting from, is the Ivy Generator and then CB Modeler Pro.
I really like that Ivy Generator.
