jestmart opened this issue on Jun 01, 2007 · 11 posts
jestmart posted Fri, 01 June 2007 at 9:34 PM
This is driving me crazy!!!
I thought I had figured away of fixing the vertice order issues using UVMapper Classic.
I swear when I did this a few weeks ago it worked, but my latest attempts failed.
Here is my work routine:
Export out the body parts one at a time with UVs
Load part into UVMapper and export out UVs with Mapper Regions selected
Import part into Blender with Morph Targets, Groups, and Clamp Scale=0; create a new Vertex Group. Continue til all parts I need are loaded.
Select All parts and Cntr-J to merge. Tab to Edit Mode Select All and Remove Doubles to weld seams.
Make changes
Use previous assigned Groups to separate back into parts
Export with settings Selection Only, Rotate X90, Morph Targets, UVs, Group
Load Targets into UVMapper and Import UVs. This is where things are going wrong.
Instead of importing I'm getting an error "Incompatible Facet Structure".
Has anyone been able to make morph tagets?
