alphauser51 opened this issue on Jun 02, 2007 · 10 posts
alphauser51 posted Sat, 02 June 2007 at 10:41 AM
How do you make a material self illuminated in Poser?
In 3D Max this would be simple, but I cant figure how how to do this
in Poser and there is nothing in the manual or on the net.
Any help appreciated.
wheatpenny posted Sat, 02 June 2007 at 11:01 AM Site Admin
For that you would need Luminosity, which AFAIK Poser doesn't have
the closest equivalent is to make the object translucent and put a poing light inside it.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Victoria_Lee posted Sat, 02 June 2007 at 11:16 AM
Try this thread. I've been playing with it. It's not something that happens right away but with some experimentation it should happen.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2217752
Hugz from Phoenix, USA
Victoria
Remember, sometimes the dragon wins. Correction: MOST times.
stewer posted Sat, 02 June 2007 at 1:29 PM
Just set the material's ambient_color and ambient_value.
alphauser51 posted Sat, 02 June 2007 at 2:09 PM
Im trying to illuminte an video clip mapped to an object.
To simulate the glow of a tv monitor with an animated video.
odeathoflife posted Sat, 02 June 2007 at 3:48 PM
You are going to have to cheat by using a spot light, and maybe depending on the situation, some volumetrics.
stwerer is right though ( as always LOL) you will have to boost the objects abients.
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Acadia posted Sat, 02 June 2007 at 4:34 PM
Attached Link: http://www.runtimedna.com/mod/forum/messages.php?ShowMessage=277007
If anyone can help, it's bagginsbill. Have a look at that thread. It might help you. If not you can try posting to ask if it's possible for your project."It is good to see ourselves as
say." - Ghandi
Angelouscuitry posted Sat, 02 June 2007 at 10:24 PM
Attached Link: glow effect in poser help!
See my post from Thu, May 17, 2007 5:17 pm for more ideas.bagginsbill posted Sun, 03 June 2007 at 7:11 AM
Confusion alert.
Self-illuminating? You mean you want an object to be bright even if there are no lights in the scene, right? No problem - use the ambient as people said. For a movie or image map, you don't even have to do that. Plug it straight into the Alternate_Diffuse input. Make sure you turn off Diffuse_Value and Specular_Value, unless you want to simulate a glass surface on top of the image - then use specular as well.
Illuminating other things? Its best to set up one or more lights (spot or point) parented to the object. A point light just in front of the middle of a TV screen works pretty well Use ray-traced shadows on it. You could use spot lights, but they only spread up to 160 degrees - so I use two or more if I need a lot of nearby objects lit, to get those last 20 degrees covered.
Illuminated BY other things? That would be the Gather node, but it is really bad - produces grainy results or is excruciatingly slow.
Angelouscuitry posted Tue, 19 June 2007 at 10:08 AM
