AbaloneLLC opened this issue on Jun 07, 2007 · 13 posts
AbaloneLLC posted Thu, 07 June 2007 at 9:58 AM
The version you can buy at Rendo is the new FaceShop 3.15 (SR1).
If you bought your FaceShop at DAZ, you can get a FREE upgrade at DAZ (simply reset your purchase, old serial works).
Laslo
HeRe posted Thu, 07 June 2007 at 4:24 PM
When I reset on DAZ my purchase I become the same old version 3.1 for the download.
What is wrong ???????
Web-Hunter posted Thu, 07 June 2007 at 4:50 PM
YES!!! I become also the old version 3.1 and not the updated version 3.15 SR1 !!!!
AbaloneLLC posted Thu, 07 June 2007 at 5:05 PM
Quote - When I reset on DAZ my purchase I become the same old version 3.1 for the download.
When you reset your purchase, you should be receiving a new installer. The installer will install a folder. (old serial will work on new software)
Inside the folder you will find:
(FaceShop 3.15
New Manual
Tutorial
New Sample file - benci)
You can tell if this is 3.15 if the sofware has a 2048 x 2048 option, save and exit manu, etc.
Or by opening page 1 of the manual. If it says "What's New in SR1?" then you have the new software.
Laslo
HeRe posted Thu, 07 June 2007 at 5:18 PM
Yes, sorry it whas a mistake. Your download-PDF-File is the old-version 3.1 - the Faceshop-program comes with the same Filename as a new version 3.15.
In the ZIP-program-file is the new PDF-documentation version included.
Klutz posted Sun, 10 June 2007 at 2:05 PM
I reset downloads & still getting 3.1....
I'll try again, I suppose...
An 'About' box giving a revision number would help. :0/
Life is a beta.
In faecorum semper, solum profundum variat.
Klutz posted Sun, 10 June 2007 at 2:22 PM
Nope still 3.1.... No 'benci' after re-install... :0(
Life is a beta.
HeRe posted Sun, 10 June 2007 at 3:54 PM
The whole program is programmed slovenly. One can not even see with which version one works is only one bug of many.
AbaloneLLC posted Sun, 10 June 2007 at 4:12 PM
HeRe,
Maybe the program is not the only thing slovenly here.
When you click on the info button (BIG RED ARROW, so that even you can see), it gives you the info about the product version, the creation day and so on.
Good morning.
Laslo
Klutz posted Sun, 10 June 2007 at 4:28 PM
Odd..
I am still getting 3.1 when I click that box, but I am able to select 2048x2048
So do I have the revised version?
:0/
Life is a beta.
HeRe posted Sun, 10 June 2007 at 5:20 PM
Yes, - Good morning!!!!????
If I this button operate I get the version number 3.1 to see, although I work with the version 3.15.
GoodMorning Sir.
AbaloneLLC posted Sun, 10 June 2007 at 6:23 PM
Quote - Odd..
:0/
You do. Only SR1 has the 2048 res.
Laslo
Klutz posted Sun, 10 June 2007 at 6:33 PM
OK Thanks! :0)
Life is a beta.
