RCT opened this issue on Jun 13, 2007 · 8 posts
RCT posted Wed, 13 June 2007 at 4:32 AM
Apologies if this seems a little dumb, but I just can't figure out how to do this... I need to do an M3 character who has no eyelashes, and I can't seem to turn them off or make them invisible. I seem to vaguely remember I could do this in Poser 4 (but I could be wrong), but I'm using Poser 7 now.
Tashar59 posted Wed, 13 June 2007 at 4:40 AM
Go into the material room and select lashes and then turn transparency up to 1. Specular to pure black and highlight size to 0.
RCT posted Wed, 13 June 2007 at 4:55 AM
Hi, thanks very much!
RCT posted Wed, 13 June 2007 at 5:10 AM
Actually, I just tried it, and it didn't make any difference!
Tashar59 posted Wed, 13 June 2007 at 6:36 AM
Just guessing but do you have a texture connected to the Trans? Disconnect the texture or delete it.
Or did you render to see if the lash are invisable. Will still show a bit untill render.
RCT posted Wed, 13 June 2007 at 6:48 AM
Hi, no there's no texture. And the lashes are still there in the render, too. What if I made a transparency map that was just all black, and replaced the existing lashes one? That sounds like it would work in theory... but it still seems like a lot of unnecessary work. Surely there's something I can just toggle on and off?
Tashar59 posted Wed, 13 June 2007 at 2:00 PM
"and replaced the existing lashes one"
You said there was no texture. Transmap is what I was talking about when I said texture connected to the Trans dial. Delete that and use the settings I gave you. You don't want anything connected to your trans dials and make sure the next 2 trans dials are set to 0 also.
Tashar59 posted Wed, 13 June 2007 at 2:08 PM
