Forum: Vue
Subject: What am I doing wrong with my animation?
ajtooley opened this issue on Jun 15, 2007 ยท 9 posts
ajtooley posted Fri, 15 June 2007 at 10:21 AM
I've been working on an ME 109 animation, but I get occasional "glitches" on the images. Sometimes it's blown-out light as if it were a reflection gone awry, and sometimes it's pure black spots. I can't figure it out.
Here's the video.
Since Google video is a tad small and compressed, here's a still frame showing the black glitch.
I appreciate any help you might give...
Mazak posted Fri, 15 June 2007 at 11:34 AM
This effect looks like you use World-Standard mapping for some parts of your object. :blink: Change to Object-Standard for mapping, and it should work.
Mazak
Google+ Bodo Nittel
ajtooley posted Fri, 15 June 2007 at 4:20 PM
I'll give it a shot. Thanks!
ajtooley posted Fri, 15 June 2007 at 6:19 PM
Hmm. Turns out everything was on Object Standard. Any other ideas?
Mazak posted Sat, 16 June 2007 at 2:46 AM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2390404
Hmmm.. Is your object imported from Poser? 😕 Check this link.
Mazak
Google+ Bodo Nittel
ajtooley posted Mon, 18 June 2007 at 12:42 AM
Yes, it was imported from Poser...
Your solution from the other thread appears to have worked! Thanks a million!
Mazak posted Mon, 18 June 2007 at 3:10 AM
Mazak
Google+ Bodo Nittel
dashboard_jehovah posted Mon, 25 June 2007 at 7:57 PM
How did you get the camera to follow the plane...animate the plane only?..or stationary camera following flight path?
Thanks for any info...I have a few Vue animations in my gallery.
Cool work,also!
ajtooley posted Mon, 25 June 2007 at 8:24 PM
Thanks!
I just set the plane as the tracked parent for a stationary camera and then moved the plane past. I'm still struggling with more complicated moves than that!
